08-18-2023, 09:46 AM | #23 | |
![]() ![]() 459
Rep 1,297
I am looking into this retrofit and looks like it is not too expensive from paper... Only expensive in time as wires run all over the car.
From what I found out you don't need all handles to be Comfort Access, so you can start with driver only. Keys probably don't need programming as our cars already have convenience Access aka, start the car with the key in your pocket. I also ran a TAL calculation against with edited VO for 322 and no missing hardware showed up in 322. for my car. Everything was black so I assume I don't need new BDC if that is ever the case. Only thing I don't know why / what is the function of the tailgate lock button? I cannot find this button on wire diagrams either. I currently have Number 2 installed, do I really need to change this one to number 4? ![]() Quote:
1. I believe you don't need everything but you definitely need all antennas 2. Why? I think we can skip some corners, F45 2016 model for example only had front doorhandles installed. I don't think there is a check for door handles, there however is a check for antennas which will result in fault code if not installed. I think also these two FDL values in BDC_Body can be used to controlled if Doorhandle is comforat access or not but not sure. Anyway, might be interesting to be noted. CAH_ENABLE_REAR CAH_ENABLE_TAGE_PASSENGER 3. Yes, must, nothing to add. 4. I have came to the conclusion that BDC 6825528 is used in production of cars however cannot be bought as (spare)-part. Not all parts are listed in ETK / realoem. Does anybody know which interior antennas are preinstalled? I guess; 1x steering column, close sensor 1x center console front 1x center console back So I think we only need to retrofit; Sideskirt L (exterior) Sideskirt R (exterior) Rear Bumper (exterior) Luggage compartment (interior) I got a deal for 200 EUR on smart opener ECU + Sensors, 1 exterior antenna and 1 interior antenna and Left Hand doorhandle, so I took the plunge. For the 5DP retrofit I need to run some wires to back of the car so I thought I could also run the wires from the rear bumper to front as well. |
wcruzeiro56.50 |
10-13-2023, 04:09 AM | #24 |
![]() ![]() 459
Rep 1,297
Took the plunge.
Part 1: Retrofitted first part, the contact free tailgate opener / smart opener & antenna in rear bumper. ToDo Doorhandles + wiring (came back from painter today) Sideskirt antennas Trunk antenna (easy) ![]() Last edited by mrpingu; 10-13-2023 at 07:56 AM.. |
wcruzeiro56.50 |
10-16-2023, 03:50 AM | #25 |
![]() ![]() 459
Rep 1,297
Installed the driver doorhandle, that was more work than I expected.
Some notes: 1. The door handle support is different for CA/non-CA. The metalpart & doorhandle have mirrored bumps so you can't get a non-CA handle in a CA-handlesupport and vice versa. 2. To get the support out you have to get the locking mechanism out aswell, otherwise there is not enough room to get it out. Custom wiring has still to be made, used already 1m to get the wire from handle to inside, so next time it will be easier to just splice to pull wire to the door connector. For now skipping the passengerside doorhandle as this is quite a hassle and I am not done yet. Next up 1. Finishing wiring in driver door 2. Installing antenne in driver sideskirt. Last edited by mrpingu; 10-20-2023 at 05:42 AM.. |
wcruzeiro56.50 |
10-19-2023, 03:09 PM | #26 |
![]() ![]() 459
Rep 1,297
Today installed the luggage compartment antenna, probably the easiest one.
Note: I still have to pull the wires to the front to the BDC but now I have all needed wires at the back and can do it at once. The last picture also shows where the smart opener and antenna come in to the car. |
wcruzeiro56.50 |
10-30-2023, 12:37 PM | #27 |
![]() ![]() 459
Rep 1,297
Added passenger sideskirt antenna and also fitted front PDC wire in 1 go as both need to go through the firewall. Used an empty grommet and looks pretty neat if you ask me.
Only don’t really know how the wire from the antenna once you get the edge of the wheel arch. But I just put it somewhere where I would see it fit but not totally satisfied… Also TIS/ISTA shows the antenna in the middle of the sideskirt but if you look up the X2 you will find it is actually on the end near the rear wheel.
Retrofits done: 2TB, 235, 313, 430 459, 508, 5DP, 322, 674 , 6CP, 323
Other mods: Central Locking button on both sides, Add extra trunk lights Other info: F48 Fuseguide, CarPlay 6CP - OEM way |
wcruzeiro56.50 |
11-08-2023, 04:02 PM | #28 |
![]() ![]() 459
Rep 1,297
Today I programmed the BDC and the installed antennas were recognized.
Found however out that smart opener module didn’t work and have a fault code for that but that’s probably due that I installed a module from 2013 car. The ETK list another number so it probably is myself to blame for using wrong part. I installed a box with white connectors but from all images of the right part number it should be totally black. So will have to fix that. |
wcruzeiro56.50 |
11-11-2023, 01:02 PM | #29 |
![]() ![]() 459
Rep 1,297
Update:
Replaced the smart opener module and it worked ![]() This means the rest of the Comfort Access retrofit will probably gonna work as well when I get to to connect all cables Still have Install driver side skirt antennas, this is now directly connected to BDC with short wire for test purposes. Install doorhandle passenger side And wire up the driver handle All in all this retrofit is a pretty big job but just wanted to inform that is definitely possible. But for next time buy a car with it ![]() wcruzeiro So put this one on your list aswell ![]() |
wcruzeiro56.50 |
11-21-2023, 05:46 PM | #30 |
![]() ![]() 459
Rep 1,297
So now is driver antenna installed. Getting the sideskirt off is really a fight because it’s hard to reach the tabs.
Next up: Wire through the firewall at the driver side. Then connected the door connector and then pull wire to BDC from driver side. Last 2 images are “switched” the wire comes up from the wheel arch/side panel and then I route it along the hood-release cable and found that there is a free grommet which I am going to use to get into the cabin. Last edited by mrpingu; 11-21-2023 at 05:53 PM.. |
wcruzeiro56.50 |
11-23-2023, 04:54 PM | #31 |
![]() ![]() 459
Rep 1,297
Aaaaand it’s working: pulled the wire from driver side to passenger side, so driver handle & driver antenna er now connected to BDC and all functions work now.
wcruzeiro56.50 |
12-21-2023, 01:31 PM | #32 | |
![]() ![]() 57
Rep 101
Drives: BMW X1 F48
12-21-2023, 01:50 PM | #33 | |
![]() ![]() 459
Rep 1,297
I still have to replace the passenger doorhandle & the tailgate button but everything else works as expected and no errors ![]() I have in mind rewriting parts of my posts in a separate topic with images etc.
12-28-2023, 07:44 AM | #34 | |
![]() ![]() 57
Rep 101
Drives: BMW X1 F48
Was it necessary to change the BDC module? If it is possible, can you make a video of how the S322A works? Thank you. |
12-28-2023, 10:01 AM | #35 | |
![]() ![]() 459
Rep 1,297
Another way to double check is to calculate(TAL calculation tab in e-sys) a SVT_soll with 322 in FA, if it shows correct HWEL you are good. I have a video but just need to upload it somewhere. This forum doesn’t take it.
wcruzeiro56.50 |
01-04-2024, 03:35 AM | #36 | |
![]() ![]() 459
Rep 1,297
https://youtube.com/shorts/E7shpTZ0vAU
wcruzeiro56.50 |
01-12-2024, 12:24 PM | #37 | |
![]() ![]() 57
Rep 101
Drives: BMW X1 F48
Can you share the SKU of the aerial antenna connectors? |
01-12-2024, 02:05 PM | #38 | |
![]() ![]() 459
Rep 1,297
exterior antenna connectors (sealed) 61138365340 interior antenna connectors 8377064 |
wcruzeiro56.50 |
08-26-2024, 08:20 AM | #39 |
![]() ![]() 57
Rep 101
Drives: BMW X1 F48
Taking advantage of the fact that the car is disassembled for the KAFAS retrofit, I routed the wiring for the Comfort Access antennas S322A. Basically, the same path already taken by mrpingu
I compiled a list of the necessary materials: - 2x side skirt antennas, right and left (65209220831) - 1x bumper antenna (65209220831) - 1x Smart Open module (61357932682) - 2x Smart Open antennas (61357391042, 61357391043) - 1x internal trunk antenna (65209220832) - 1x Mount for contactless opening tailgate (51127378532) or Msport (51128059886) - 1x switch (61319275121) Connectors: - 3x external antenna connectors (61138365340) - 1x internal antenna connector (8377064) - 2x Smart Open module connectors (754331202) - 1x Smart Open module connector (692559504) Door Handles: - 1x Door handle left (51217433843), (51217401211) - 1x Door handle right (51217433844), (51217401212) **I had forgotten the clips for the Smart Open antenna:** - 6x mounting clips (52208133466) Next steps: - Send for painting and install the door handles. - Connect everything to the BDC. - Coding. |
09-11-2024, 06:24 PM | #41 |
![]() ![]() 57
Rep 101
Drives: BMW X1 F48
Evolving at a turtle's pace...
I didn’t find the PIN information for the X281B and X51B connectors in the ISTA documentation. So... In my case, the door handle connector was provisioned and internally secured with tape. I just needed to figure out the PIN configuration. To do this, I used simple tests with a multimeter. The X28*1B connector is for the driver side, and the X5*1B is for the passenger side. This is for a left-hand drive vehicle. PIN configuration for X28*1B: 11 to Brown (only this is already connected) 23 to Red 24 to Yellow I believe the PIN standard will be the same on the passenger side, but I still need to confirm this at the next opportunity when I continue the retrofit. |
mrpingu459.00 |
09-12-2024, 01:15 AM | #42 |
![]() ![]() 459
Rep 1,297
Lucky you that the connector already was there
![]() Remember to change the door handle support, otherwise you won’t get the CA-handle in.The hooks are mirrored: https://f30.bimmerpost.com/forums/sh...813025&page=12 Passenger side has same pin configuration. Door connectors are a pain to get out in front in my opinion. You have to dissaasemble quite a lot. |
wcruzeiro56.50 |
11-01-2024, 02:30 PM | #43 |
![]() ![]() 57
Rep 101
Drives: BMW X1 F48
Yes, to run the wires for the passenger handle (on my left-hand drive), I had to remove the BDC from its place.
It’s not difficult, just a bit labor-intensive. You need to take your time with it. Removing the BDC was helpful because during disassembly, I noticed that I had connected a pair of wires for the SAS and KAFAS retrofit incorrectly. ![]() |
MJE60783.00 |
11-02-2024, 04:40 PM | #44 | |
![]() ![]() 783
Rep 1,037
wcruzeiro56.50 |
