E91 - Tweeter Upgrade Part Number Help
10-16-2008, 06:33 AM | #1 |
70
Rep 1,733
Just called up to order the L7 Tweeter upgrade to my 09/2007 335D Touring
I was given the price for the DSP Tweeter £90.45+VAT and he reckoned that was the full kit including the grilles (?) Is the DSP tweeter the L7 tweeter? i.e i'd like to fit the best tweeter, as i understand the price difference is negligible and i'll be upgrading the amp at some point. The part number given to me was 65136944462 I've looked on Reoloem http://www.realoem.com/bmw/showparts...30&hg=65&fg=20 And i can't see that this is correct. Sorry for being a pain, but can someone with an E91 confirm what part numbers i need for the L7 Tweeter upgrade to basic hifi system (i.e the one without a tweeter) in an E91 Thanks in advance. |
10-16-2008, 08:41 AM | #3 |
240
Rep 2,810
Drives: Jaguar XE P250 HSE
If it's the same as the E92, you have to buy replacement covers at the mirror which come with a built in grille, the tweeters are sold individually but you should be able to get each one for about £40 including VAT.
You need a new foam seal for the covers as it has a recess in it to take the tweeter and an extra cut-out on the edge for the cable but, as gIzzE has said, just use the original foam inserts and cut out the holes required - that will save you about £12. You can see my experiences here from post # 55 onwards. HTH |
10-16-2008, 09:30 AM | #4 |
362
Rep 5,984
Alpins speakers now available too...
http://www.realoem.com/bmw/showparts...94&hg=65&fg=95 Have a look there for the part numbers for the new trim/grilles. |
10-16-2008, 09:48 AM | #5 |
240
Rep 2,810
gIzzE, does that kit include the tweeters and the 2nd set of rear speakers to bring it up to the equivalent of the Hi-Fi option?
10-16-2008, 10:32 AM | #6 |
362
Rep 5,984
Don't buy any upgfrades for the rear speakers, when set up properly you will cut the rear high level out anyway.
That Alpine upgrade is and amp and front speakers, not sure if you can buy the speakers without the amp though??? |
10-16-2008, 10:58 AM | #7 | |
74
Rep 2,937
10-16-2008, 12:24 PM | #8 | |
1135
Rep 2,808
10-16-2008, 02:10 PM | #9 | |
70
Rep 1,733
Once again, thanks for answering (good way of getting the grilles part numbers) But.....as usual...more.... What model/specs of amp is that? i.e is it a good substitute for the 555 and will it drive SWS-8's under the front seats? I had planned on doing it the Blaupunkt way that you did and wrote up so well, but if you think this is as good, suits me. Thanks |
10-16-2008, 02:13 PM | #10 |
362
Rep 5,984
10-16-2008, 02:14 PM | #11 |
362
Rep 5,984
10-17-2008, 09:18 AM | #13 |
70
Rep 1,733
Just ordered the following at a cost of £102.
02 TOP-HIFI LOUDSPEAKER TWEETER 2 65136964013 $77.28 01 COVER, WINDOW FRAME, DOOR FRONT LEFT 1 51337171201 $32.64 01 COVER, WINDOW FRAME, DOOR FRONT RIGHT1 51337171202 $32.64 02 SEAL, INNER LEFT MIRROR TRIANGLE 1 51337120659 $10.71 02 SEAL, INNER RIGHT MIRROR TRIANGLE 1 51337120660 $10.71 No mention of spring clips. Should arrive middle/end of next week. |
10-17-2008, 09:26 AM | #14 |
362
Rep 5,984
The foam that people are ordering is already in your car, you just need to pull out enough to pop the tweeter in, saves £20 and you only end up throwing one lot out.
10-17-2008, 09:27 AM | #15 | |
70
Rep 1,733
EDIT: Cancelled the seals. And ordered a 2nd speaker - i guess that helps Different guy on the phone noticed that only one had been ordered! Will update final price when i go pick them up. G - THANK YOU ONCE AGAIN |
10-17-2008, 09:38 AM | #16 |
240
Rep 2,810
misterS3, where did you order the parts from? Note that you'll have to cut out a circular recess in the existing foam and a small slit at the bottom for the wires.
Would it have been Park because they only ordered one tweeter for me because the description on their system says "tweeter - set" which is a bit ambiguous. |
10-17-2008, 09:44 AM | #17 | |
70
Rep 1,733
Yeh it was Parks and i'm guessing you're the "very clued up guy with the E92 who even hard part numbers" who ordered last week |
10-17-2008, 09:53 AM | #18 | |
240
Rep 2,810
10-17-2008, 12:27 PM | #19 |
70
Rep 1,733
Just had a look close at my car and the plastic bit on the inside of the car, which is opposite the mirrors i.e where the tweeter goes, appears to be attached all the way around the window frame too?
I'd assumed it was just the triangle in the corner. Confused.com! |
10-17-2008, 12:33 PM | #20 |
240
Rep 2,810
gIzzE is the man to tell you about this as he did it to his E91
10-17-2008, 12:39 PM | #21 |
70
Rep 1,733
10-17-2008, 01:59 PM | #22 | |
362
Rep 5,984
Tags |
e91 tweeter speaker |
