12-26-2020, 12:46 PM | #1 |
Hi!
54
Rep 87
Negative camber recommendations
Hi. This is mainly in regards to autocross with an occasional road course. Within the factory range, is it possible to get a good enough negative camber for autocross without having to swap or upgrade hardware? My friend is going to help me out at his alignment shop so I figured I'd take the offer.
If this is possible, what numbers should I have him try to dial my alignment to? Thanks. |
12-26-2020, 03:01 PM | #2 |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
This isn't possible on the front (there's no adjustability built in). In the rear there's lots of adjustability, but it's not that helpful without the front. For the front you can get camber plates or eccentric bushings for the LCAs. No HW swap is required for the rear.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
12-26-2020, 05:48 PM | #3 | |
Hi!
54
Rep 87
12-27-2020, 05:13 PM | #4 |
156
Rep 320
No is the short answer to your question. When I ran in stock class, the best I could do up front was -0.8 degrees of camber. rear camber was not a problem, you can easily get -2 degrees in the back.
what size of tire do you plan on running? PS4S is a good tire but it will not heat up fast enough for autox...not even in Cali! You can still use them and have fun but it won't be the quickest. The wider tire you run the less camber you will need. just to give you a base line, I typically run my car in STU (Street Touring Ultra in SCCA classing) and for autox i am around -2.3 in the back and -2.9 up front. That's only using camber plates up front. The car is on a 265 wide tire in all corners. I'm lowered about an inch and judging by feel -2.9 is not enough for the front and -2.3 is too much for the rear. Bare in mind that i'm xdrive with an inline 6 so my battle with weight management and traction is a bit of a challenge when aiming to remain in my class. Having said all that, you are in a lighter RWD car that has AFAIK better balance and weight management characteristics than the 335 xdrive so you may not require as much camber. I would recommend camber plates for front camber. That in my experience is the easiest way to achieve camber effectively and most of them will get you between -2.5 and -3 degrees. I've tried the offset KMAC bushings in the control arms and they work well but they are more challenging to adjust between autox runs because you have to remove the wheel to get tools in there etc. it is somewhat inconvenient. |
12-27-2020, 08:06 PM | #5 | |
Hi!
54
Rep 87
I just bought TC Kline front camber plates off a forum member today to help with front adjustment. |
12-27-2020, 10:09 PM | #6 | |
4017
Rep 3,540
As for alignment numbers, try somewhere in the range of -2.5 to -3deg camber, 8deg of caster (if you can), 0.03deg toe in each side for the fronts. For the rears start with -1.8 to -2deg camber, and 0.05 to 0.08deg toe in each side.
12-27-2020, 10:23 PM | #7 | |
Hi!
54
Rep 87
12-28-2020, 10:56 AM | #8 | |
156
Rep 320
Enjoy!! |
