12-17-2020, 06:53 AM | #1 |
enthusiasm > practicality
4027
Rep 2,247
Drives: 987 CS | G35x
Snow tires on a RWD performance car
It’s that time of year again, time to rekindle the second most polorizing topic (right behind manual vs DCT), snow/winter tires on RWD vs all-seasons on AWD. My region received about 10” of snow yesterday and last night. This morning at 5 am, I made the 5 mile trek into work. The commute which normally takes 10 min took 15, mainly due the fact that I was behind a tag team DOT plow truck couple, a good scenario for sure. Needless to say, my journey was not only uneventful but inspiring as well. My decision to invest a few hundred dollars on a winter tire/wheel setup once again (my previous ‘16 M2 was also equipped on Blizzaks) gave me the utmost confidence while driving on snow covered roads. I must give PA DOT their props for doing an excellent job at snow removal. My ground clearance is about 4” so any snow banks in intersections would’ve probably impeded my commute. I had all-season runflats on my ‘14 435i xDrive. Firsthand experience will tell you RWD with snows are more effective overall. My specs:
KW coilovers at highest setting Perelli Sotozero mounted on cheapo Tirerack steel wheels No LSD ~65/35 rear weight biased due to mid engine
FSI 3.8L Stg II|6MT|SOUL|IPD+GT3 TB|Numeric Racing|KW|Tarett|Rennline|Raceseng|APEX|Recaro|7.3 lb/hp
VQ35HR|5AT|Stillen|FI|UpRev tune 8k rpm|TransGo|Hotchkis|Whiteline|H&R|Z1|Corbeau|R1 Concepts|10 lb/hp Left lane campers, GTFO! |
12-17-2020, 07:06 AM | #2 |
14118
Rep 1,336
Drives: Porsche 993
So just a few things, your RWD is also rear/mid engine which helps significantly in a similar fashion to FWD. I have had the pleasure (not really) to have lived for almost 60 years in Canada with about 45 years of driving experience. Winter tires are the way to go for a number of reasons that are pretty common knowledge. I have had AWD with all season when living in the city and I got buy with them 95% of the time, but frankly when there was heavy snow or ice they were shit, and they weren't the best in summer either. They are a compromise in every scenario. I know have a small SUV with good ground clearance, AWD and proper Winter tires. I have complete confidence in this set up, deep snow, slush, icy roads and they are pretty good on dry pavement. Regarding the cost, they are on the truck about 5 months of the year, so besides the initial outlay of cash you end up doubling the life of your summer tires. Happy winter driving, and it's snowing right now dammit.
12-17-2020, 07:17 AM | #3 |
3085
Rep 1,828
How does the front handle slushy conditions on the mid engine? Does it seem to plow a bit more vs more front weighted cars?
Winter tires may not help you accelerate faster but definitely help you handle and brake. I've always been an advocate for winter tires if your area receives regular snow. I will never go without them now. |
12-17-2020, 07:26 AM | #4 |
1463
Rep 2,151
As F1 teams know: always be on the right tire!
Is see too many people thinking that AWD is all they need because the marketing brochure said so when they were buying the car. In snowy winter: Winter tires+AWD > Winter tires+RWD > AWD > RWD BTW, that GT4!!! My next dream car, although I'd "settle" for a GTS, too! |
Murf99314118.00 pennsiveguy3552.00 |
12-17-2020, 07:38 AM | #5 |
6574
Rep 3,043
AWD is the single biggest piece f marketing fluff ever invented in the automotive world. It helps but it is not a miracle worker. It doesn't help you brake either which is the biggest safety issue in winter.
Nothing, but nothing works better in snow and ice than proper tyres. I am not crazy about Pirelli TBH, I find for serous snow the Blizzacks are best and mixed conditions the Michlen XIce do a great job. I run XIce as our streets are ploughed and they are far less noisy and wear better than the Blizacks. Last edited by Alfisti; 12-17-2020 at 07:48 AM.. |
12-17-2020, 07:46 AM | #6 |
4027
Rep 2,247
Thanks for the comment. It's not a GT4 though. I installed GT4 side scoops to allow more air into the engine. A poser move perhaps but these OEM scoops are much cheaper than the carbon fiber aftermarket scoops currently on the market. Besides, when all modifications are done, including new 3.8L powerplant, it'll be at 981 GT4 performance capabilities.
12-17-2020, 07:48 AM | #7 |
4027
Rep 2,247
Michelin Blizzaks and Alpin aren't available in my size so I had to settle for the Perellis. They're still quite capable.
12-17-2020, 08:21 AM | #8 |
11665
Rep 1,830
Drives: E86 3.0si
Garage List '55 Ford F100 [0.00]
'08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [0.00] '19 VW Golf "R ... [0.00] |
Let's not forget snow chains...
jmack550.00 |
12-17-2020, 09:10 AM | #10 |
14118
Rep 1,336
Drives: Porsche 993
12-17-2020, 09:43 AM | #11 |
3085
Rep 1,828
I think chains are really only good for the mountain areas (BC, AB). Even then, only under certain conditions.
QC has a mandatory winter tire law for the winter months. I believe tourists can be ticketed if they don't have the snowflake on their tires as well. Studded tires are more common in the northern latitudes. I haven't seen them used much south of Sudbury. |
12-17-2020, 09:54 AM | #12 |
4027
Rep 2,247
Unless that's some unicorn 'Stang with fwd, then yes.
12-17-2020, 10:27 AM | #13 | |
3552
Rep 1,062
Drives: F15 xDrive50i M-sport
My X5 is a whole 'nother matter, though. Easy to steer with the throttle on snow, but the front wheels are spinning too regardless of conditions and with no delay whatsoever. Vastly superior system.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
12-17-2020, 10:29 AM | #14 | |
3552
Rep 1,062
MBM3401026.00 |
12-17-2020, 11:36 AM | #15 | |
E4 Mafia
329
Rep 418
I believe the AWD gains in "traction" in adverse conditions are minimal compared to the larger change that occurs in the average drivers head, overconfidence.
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k) | '04 E46 330xi MT (198k) | '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
12-17-2020, 12:42 PM | #16 |
3360
Rep 1,823
12-17-2020, 12:49 PM | #17 |
6140
Rep 3,661
awesome. i hope everyone that dumped their M3 for an X3M because of 'weather' sees this post. i just run michelin cross climates on my civic, seems to get the job done fine with a few inches of accumulation on the highway.
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
No Boost4027.00 |
12-17-2020, 01:06 PM | #18 |
4027
Rep 2,247
What you should do is equip the GT3 with winters and have someone record you doing snow donuts in a vacant parking lot for all to enjoy.
Humdizzle6139.50 |
12-17-2020, 03:24 PM | #19 |
5160
Rep 3,242
All this talk about AWD and traction to get you going. No thought around once you get going, you also have to stop at some point. AWD will do squat if your tires can't produce enough friction/traction to haul your tank to a stop.
No Boost4027.00 pennsiveguy3552.00 |
12-17-2020, 08:23 PM | #20 |
Post Advisor
1653
Rep 1,710
The ultimate proof that winter tires make the biggest difference:
We winterized a Viper...640hp and 600lb/ft to the rear wheels with a stick shift in the snow. We were the first to do this. Everyone thought it was impossible. Check out the slalom and donuts...all proof of complete car control. |
12-17-2020, 08:50 PM | #21 |
219
Rep 76
Kept my 11 year old Evo X with Blizzaks for moments like these, doesn't get any better than that in the snow.
12-17-2020, 10:32 PM | #22 |
3552
Rep 1,062
Yeah, it's kinda like flying a plane. Taking off is optional, but landing is mandatory.
