11-21-2020, 02:43 PM | #1 |
Rep 32
HK Setttings
I have found the equalizer settings on other threads are pretty good, but Not the fader setting. Has anyone else has found that they need to set the fader to the rear about 4 clicks to balance the sound out? I may have been imagining it, but it also seemed that bass from the subs got louder.
Prior to that fader adjustment I thought the system sounded better with Logic 7 on. However, with the fader set more to the rear I may like it better with it off. Not sure if it makes a difference, but I have a 2021 X3 M40i. It appears the HK amp equipment is different compared to the older G01's.
Scott Thomas
11-24-2020, 09:30 AM | #3 |
Best of Both Worlds
86
Rep 89
I also have my fader set a couple clicks towards the rear, but my seat is adjusted about half way through its range as well. I just assume that the baseline fader setting assumes the front seats are at the back of their adjustment range, so it makes sense for me to compensate by fading the sound to the rear.
