TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Burning oil and oil in coolant expansion tank
      10-26-2020, 11:32 AM   #1
jmiske4
jmiske4's Avatar
Drives: 2008 BMW 335i
I have a 2008 bmw 335i convertible n54 engine I drove my car to school a couple days ago and burned a lot of oil about enough to bring up the check oil light in my car. I go to start it this morning and it brought up the check coolant light and checked the coolant expansion tank and there was no visible coolant and I looked down inside the tank and found a dark chocolate like substance I'm thinking it is oil but I'm not sure how to go about it because Im going to do a coolant flush and see what it might be and don't want to start the car without knowing what is wrong
JM
      10-27-2020, 08:59 AM   #2
m_thompson
m_thompson's Avatar
133
Drives: M-Sport 128i, 328xi, 3.0CS
2009 128i  [0.00]
1972 3.0CS  [10.00]
Probably needs the oil filter housing gasket replaced.
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
      10-27-2020, 04:51 PM   #3
e91Owner
e91Owner
425
Drives: 2011 e91 & 2010 e60
Yep. Sounds like your OFHG is probably gone. You can probably see oil/salt residue pooling below the intake manifold.
      10-28-2020, 11:13 PM   #4
jmiske4
jmiske4's Avatar
I had a dealer replace the ofhg before I posted this and I feel it might be residue oil but still so confused on the coolant
JM
      10-29-2020, 02:28 AM   #5
Peckarami
Drives: BMW E92 335i
The OFHG has both oil and coolant passages. If the gasket between the oil and coolant has failed, that could be the source of the 'gunk' in the expansion tank.
I literally just replaced the oil cooler on my other halfs astra last week, same symptoms as you (oil in coolant) replace the cooler and no more oil in coolant.
I would have expected them to do a coolant flush if they replaced the OFHG though?
      10-29-2020, 05:12 PM   #6
e91Owner
e91Owner
425
If the OFHG (which is a very thin gasket) goes, oil has the potential to be mixed with coolant since the gasket is both for the oil and the coolant going through the oil filter housing. Just watch a video on how to change it and it'll all make sense.
      10-31-2020, 04:35 PM   #7
jmiske4
jmiske4's Avatar
I figured it out I'll need to do a coolant flush and throw some distilled water in it first then fill it with coolant after but thank you to all the people who commented and helped me understand if I should do anything different please let me know
JM
