e90 cam sensor problems? help?
10-17-2020, 08:21 AM | #1 |
Rep 19
Hello all. Am new here and need some help.
Got a bmw e90 318i 2007. Petrol Automatic. When i start the car in the morning, it starts, idles rough then cuts out. After maybe 2-3 goes it runs. I ran obd tool. It said cam sensor on exhaust. So i changed it. Same issue remains. Ran inpa, this says 2b63, same fault. But i have changed the part. So i ran ista, this shows 2b62, cam sensor on intake. Spoke to a friend who believes the timing chain may have jumped a notch and the timing in off, but inpa/ista says nothing to that effect? Someone else is saying change the vanos non return valves( not the vanos solenoids) but i cannot find this part on bmw oem as a part. Can is still running rough on start up, not always starting on first go. And sometimes needle is bouncing up and down on idle. I would really appreciate any advice insight. i have ordered another cam sensor to replace on the intake just to eliminate. Thoughts please? |
10-17-2020, 08:54 PM | #2 | |
e91Owner
425
Rep 1,129
11111734667. However, most people on will be less familiar with 318's so take the recommended fixes with a grain of salt. They are looking at your problem through the lens of an N52 engine. |
10-18-2020, 06:08 AM | #3 | ||
Rep 19
Is this a check valve or a non return valve filter? Does head need to be removed to change this? I have the second cam sensor for the intake coming on tue, after i replace this, you are saying I need to get this part that you have shown and replace that also? How many pieces do i need? Is that what is causing the fault moving from exhaust to intake cam sensor and causing the rough starts and rough idle? |
10-18-2020, 07:47 AM | #4 |
e91Owner
425
Rep 1,129
This is a non-return valve. You have to remove the cylinder head to replace it on an N46. On an N52, you do do not. In fact you don't need to remove anything. Thats why I said take the solutions with a grain of salt.
I have no idea what could be causing this problem, although other posters on the international forums have said it had to do with the timing chain. I was just commenting on the part in question. You won't find much expertise on that engine here. |
10-18-2020, 09:14 AM | #5 | |
Rep 19
Have I posted this in the correct forum? This is the e90 forum right? Or do i need to move it to another section so I may get the international members 2 cents. |
10-18-2020, 01:08 PM | #7 |
Rep 19
10-18-2020, 10:50 PM | #8 |
e91Owner
425
Rep 1,129
If you are using the app, the regional forums are the 4th line down under the e90. On the website they are towards the bottom of this page:
https://www.e90post.com/forums/index.php |
Tags |
cam position sensor, cam sensor, e90 |
