E90 N55 335i Failing Arizona Emissions
10-13-2020, 11:35 AM | #1 |
Rep 38
Alright guys, I have been going back and forth with emissions center. I don't think I've been lucky with emissions employees either. I've been been sent to the waiver center and they tell me you need your cat monitors on for us to move on (which is the only problem obviously).
Car moved from Florida to Arizona recently, I have FBO and MHD/xHP N55 E90. Since I do NOT have cats in my downpipes, and DME not showing it as ready...how can I pass? I've done the map0 with checking the oem pipes but gel CEL pretty quick. I've been searching all over the forum and internet for answers, and there does not seem to be a DPFix for N55. Any help appreciated, I'm in the Greater Phoenix area in AZ. |
10-21-2020, 02:58 AM | #2 | |
626
Rep 2,099
Could you just bolt on secondaries temporarily to pass? Or are they going full visual now for cats in the manifold? |
10-21-2020, 06:42 PM | #3 |
242
Rep 1,354
There are indeed DPFixes for the N55.
IMHO the best is the area 74 version which does not require a pot for adjustment and instead uses a PLL enhancement of the signal pulses. This will make the car sensors go ready which is what they are looking for. The DPFix can be hooked up with a switch to disable it when you don't need it and so it does not draw power. The other brand of DPFixes have a small pot (potentiometer) the you have to fiddle with to bring the signal within specs. The A7 is an enclosed box with an LED that shows it is working. Short of a DPFix you will need new cats. |
