Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > 335i E90 Possessed!!!!
      10-11-2020, 01:34 AM   #1
Justus
Drives: BMW 335i
Hi all, I am trying my hardest to locate a problem. Car was running perfect until I gave a wash (briefly in engine bay also) removed my dvr fuse and then car will not start.. Have used MHD/Protool/Carly to try find issue...
Codes are:
2A19 - DME: Tank-venting valve, activation.
2A94 - DME: Crankshaft sensor, signal.
2FBC - DME: Fuel-supply control valve, signal.
3100 - DME: Boost-pressure control, deactivation.
After attempting to start in limp mode with all the warnings popping up I have removed and cleaned Crankshaft sensor, put more fuses in as a few are empty.
Still it clears the crank error but others remain.
I live in remote bush so even harder to try help or parts.
Absolutely any insight would help, as it was perfect condition prior with exception or boost when in use and awaiting on pipes to rectify.
Thanks guys
      10-11-2020, 01:59 AM   #2
Justus
Drives: BMW 335i
Issues resolved.... After taking half of engine bay apart. 1 little fuse wasn't blown but once replaced she fired up instantly....
Faith restored thank god, as I have two of the bloody beasts.
      02-27-2021, 12:37 AM   #3
cargolue
Drives: bmw
Which fuse was it? I just got the 2FBC code only.
