10-06-2008, 02:43 PM | #1 |
Supreme Allied Commander
3776
Rep 54,162
Drives: F80 M3
R4-S High Performance Street and Autocross Brake pads for your E9X M3
high performance and heavy-duty street conditions. Perfect for prolonged everyday street use while also being capable of tolerating the most severe street use without any fade. Rotor friendly of course. The R4-S friction level will give you an impressive increase in stopping ability with very minimum pedal effort. R4-S compound has the absolute lowest noise and dust levels, far below OEM equipment or any other high performance brake material. Good for autocrossing, some drivers schools, solo events, and rally’s. The R4-S compound is available for virtually any vehicle sold in the US. We also offer the R4-S in pad sizes for competition type calipers that are used under street driven conditions.
***If there is enough interest, we can put together a GB for a more aggressive brake pad set suitable for HPDE and time trial*** F(918): $149.95 R(919): $99.95 GB here: http://www.m3post.com/forums/showthr...=1#post3428126 |
10-14-2008, 10:44 PM | #3 |
205
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
are these Porterfield RS4 pads? Are the prices each wheel or each end?
10-15-2008, 11:06 PM | #4 |
3776
Rep 54,162
Drives: F80 M3
10-16-2008, 10:27 PM | #6 |
3776
Rep 54,162
Drives: F80 M3
10-29-2008, 12:22 AM | #9 |
80
Rep 961
10-29-2008, 10:08 AM | #10 |
3776
Rep 54,162
Drives: F80 M3
12-10-2008, 09:52 AM | #11 |
71
Rep 396
Just want to give some feeds back on R4-S.
I ordered this pad from HP about a week or so before HPDE @ Street of Willow on Dec 6. The pad went in just 2 days before the event. I did a pad break-in according to Dave Z.'s recommendation; 60->10mph stop of 8 iterations and a cool down run. On the track, it didn't perform as I thought it would. The initial grip was not there. However, as the day progress and the temperature warmed up, the paddle feel and initial bite in got better. There was no noise no fuzz no fade on a hard day use @ SOW. Mind you, this is not meant for competition but merely more so of an upgrade street pad. Had I gone 30+min. session, the outcome might be different. Just for a comparison sake, I went to the track with stock brake two weeks prior. Stock OEM, while seem to bite better, maybe due to larger surface area from several months of usage, but it seems to fade a tad at the end of 25 min session. If one were to do a 15-20min session, stock OEM pad is more than plenty. However, if you need to upgrade your pad, this is it. As far as customer service is concern, HP Autowerks is my sole supplier right now.. Thanks Harold. |
12-10-2008, 10:52 AM | #12 | |
3776
Rep 54,162
Drives: F80 M3
Performance pads will have more brake torque as temperature increases until their designed operating temperature. I am glad you like how these pads perform on the track. How is it for brake dust for street use? |
12-15-2008, 10:53 AM | #13 |
71
Rep 396
Another track update..
Brake dust..much better than OEM. I went out to SOW again on December 13 with Speedventures. The weather was not so pleasant though, it was in a high 50s low 60s all day long. After the 1st warm up lap, the brake perform beautifully. However, the tire didn't warm up until 3 lap or so. I check the car when I got home that evening, brake residual on the wheel look normal, no sign of accessive brake usage at all. |
12-16-2008, 11:33 AM | #14 | |
3776
Rep 54,162
Drives: F80 M3
04-10-2009, 01:52 AM | #15 | |
3776
Rep 54,162
Drives: F80 M3
Any more feedbacks on this pad? |
08-06-2009, 09:43 AM | #17 |
34
Rep 543
My experience with Porterfield R4-S pads (on a B5 Audi S4 with the 6-piston Porsche Cayenne BBK upgrade):
The pads have very little dust and very little noise, which is a big plus. However, they have pretty much no bite at all when cold. Especially during the winter, they just wouldn't bite hard unless you REALLY heated up the brakes. After heavy braking for at least 10 minutes, they performed well enough... but I definitely wouldn't get these if you're planning to do 90% street driving. Don't get me wrong, Porterfield is a fantastic racing name, but I wouldn't recommend them as a street pad. |
08-06-2009, 07:31 PM | #18 | |
3776
Rep 54,162
Drives: F80 M3
Warm and hot temp brake torque is beyond what the oem pads can offer for sure! Feedback from one of my customer is that the cold bite is identicle to stock: http://www.e90post.com/forums/showpo...50&postcount=7 |
