10-05-2020, 11:10 PM | #1 |
142
Rep 379
I bought a pair of aftermarket taillights and now I regret not buying the OEM BMW taillights. Will drilling a hole remove the condensation? I didn't noticed it until a couple days ago even when I washed my car like 5+ times ever since I stalled it like 5 months ago.
It looks worse when it's colder I think.. |
10-05-2020, 11:54 PM | #2 |
David
786
Rep 2,009
I've heard people do that if there isn't proper ventilation, most of the time the culprit is poor sealing of the lens.
10-06-2020, 12:12 AM | #3 | |
142
Rep 379
10-06-2020, 12:16 AM | #4 | ||
David
786
Rep 2,009
10-06-2020, 12:37 AM | #5 | |||
142
Rep 379
10-06-2020, 12:37 AM | #6 | ||||
David
786
Rep 2,009
10-06-2020, 03:31 PM | #7 |
595
Rep 1,953
Drives: 2013 328i xDrive
I hear that the aftermarket ones sometimes have this problem and you need to seal it to make sure it doesn't become an issue.
10-08-2020, 08:25 AM | #8 |
Cheapskate
4455
Rep 4,995
I had an OEM one with the same issue and replaced it. drilling a hole will let it evaporate faster but then you'll see condensation every time you wash the car. Like 328iX said you need to dry it AND reseal it. But easiest thing to do is get it replaced under warranty.
10-08-2020, 09:28 AM | #9 |
8274
Rep 16,139
A hole or two may help, but the reason you're getting the fogging it's not sealed tight, allowing water to get in. Where water gets in corrosion eventually follows, so I'd see about fixing the cause rather than the symptom.
kern4174454.50 |
10-08-2020, 10:53 PM | #11 |
339
Rep 660
Drives: 2014-320Xi / 2017-330Xi
Some of these aftermarkets are terrible quality...
