The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Burnt valves on 4-6 cyl, but lean mixture on all cylinders?
      10-02-2020, 03:43 PM   #1
Refractory
Drives: E90 325i 218hp, N52B25
Engine: n52b25, huge problems in the lower rpms
Okay, so - Dry + Wet compression test results:
Dry compression test - between 12.5 and 13 bar across the board (180-190psi) which is obviously pretty low, piston rings are worn for sure.
Wet compression test is where it gets interesting - cyl 1-3: 17 bar (250psi), so obviously the few drops of oil help fill the gaps caused by the worn piston rings, but cyl 4-6 with a few drops of oil - between 13.5 and 14.5 (190-210psi), burnt valves seem to be the apparent cause. So I would understand a lean condition on bank 2 (cylinders 4-6), but why would bank 1 (cylinders 1-3) run lean?
TLDR:: Why would the car be throwing Lean mixture codes on ALL cylinders (both banks), if 1-3 only have worn piston rings and valves seem to be in order? Or would the huge compression loss from the piston ring wear also make it burn lean?
      10-09-2020, 01:54 AM   #2
Meeni
Gateropode
Meeni's Avatar
329
Drives: BMW 330i 06
I believe that seeing a lot of unburnt fuel in the exhaust (as spewed by your leaking cylinder with not enough pressure to ignite the fuel, witnessed by a high difference in pre-cat and post-cat air sensor readings) would cause the DME to lean it to compensate for what is measured as overly rich mixture?
Or conversely the O2 sensors are covered in soot from the unburnt fuel and readings of lean are incorrect because the sensors are dirty?
Tags
325i, compression, lean, low, n52, n52b25, p0171, p0174, valves
