BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > BMW F20 LCI auto/returning column stalks retrofit
      09-28-2020, 06:02 PM   #1
BMW-ALPINA
Freude am Fahren
BMW-ALPINA's Avatar
479
Drives: G26 i4 M50, F11 M550d, E70 X5
For me, the new mechanical column stalks (turn signals and windscreen wiper) are really annoying. The older F20s have stalks that returns to center automatically. Have successfully retrofitted newer type of column stalks from F15 on an F20 M140i. It looks similar to the mechanical versions, except of the auto windscreen wiper button and off course as they returns to 0-position when operating. It feels so premium and more modern now!
OEM+ customization is the way to go!
      10-05-2020, 03:58 PM   #2
JovanUK
JovanUK's Avatar
142
Drives: '17 M4 F83 CP, '18 M140i SHA.
very cool mod! how much did it cost you? also have a 2018 f20 m140, might be interested to do this
"We at BMW do not build cars as consumer objects, just to drive from A to B. We build mobile works of art" - Chris Bangle
"If it depreciates, lease it. If it appreciates, buy it."
      10-05-2020, 04:10 PM   #3
BMW-ALPINA
Freude am Fahren
BMW-ALPINA's Avatar
479
Yes, it is! It costed around 120 USD, for an F15 steering column switch with coil spring and an new button for steering wheel heating. I coded it with bimmercode.
JovanUK141.50
      02-07-2022, 04:23 PM   #4
tomo_st
tomo_st's Avatar
Croatia
Drives: e36 323ia, e36 323ti, f20 LCI2
Hello!
I have F20 LCI2 and hate mechanical column stalks. Can you help me how to code through bimmercode new column stalks which returns to 0-position when operating (i also bought stalks from F15).
      02-08-2022, 02:48 PM   #5
BMW-ALPINA
Freude am Fahren
BMW-ALPINA's Avatar
479
Originally Posted by tomo_st View Post
Hello!
Yes, off course. If you have steering wheel heating, you also ned to change the heat button from an 2AT/F15. Just send PM.
      02-09-2022, 05:40 AM   #6
tomo_st
tomo_st's Avatar
Croatia
Thanks a lot, but i can`t see a private message folder probably because i`m new member and i need to write a couple of posts before. When i get access to private message system i will ask you to help me.
      02-15-2022, 11:55 AM   #7
BMW-ALPINA
Freude am Fahren
BMW-ALPINA's Avatar
479
I sent you an PM.
      08-14-2023, 07:42 AM   #8
phoenixorion
Drives: 2018 BMW 340i
2018 BMW 340i  [0.00]
Bimmercode
I retrofitted my 2018 F30 with the old model stalks, but the far press indicator does not work. It stays on as long I am pushing it. The lane change works (3 blinks) and so does the wiper. Is there any coding required to keep the far press working?
      08-26-2023, 07:05 AM   #9
TheNine90
578
Drives: bmw
Did you code the steering column variant?
      08-26-2023, 07:47 AM   #10
phoenixorion
No. I don’t know the variant to code.
      08-26-2023, 08:30 AM   #11
phoenixorion
Also I have the bimmercode app.
      08-26-2023, 08:59 AM   #12
TheNine90
578
Drives: bmw
LIN_VARIANTE_SZL
Which option does it show?
The lci and pre-lci steering with self returning stalks have _R_ different.
      08-29-2023, 08:09 AM   #13
phoenixorion
Sorry for not responding. I was traveling I’ll update you by end of today.
      09-03-2023, 12:48 PM   #14
phoenixorion
I have szl_us_r_aic selected
      09-03-2023, 02:05 PM   #15
TheNine90
578
Drives: bmw
choose szl_us_aic if you have changed the steering column
      09-04-2023, 07:25 AM   #16
phoenixorion
Ok. I’ll try and let you know. Thank you.
      09-04-2023, 07:49 AM   #17
phoenixorion
I do not have dzl_us_aic in the available list. Should I add that as a custom value?
      09-04-2023, 07:51 AM   #18
phoenixorion
I mean szl_us_aic
      09-04-2023, 08:31 AM   #19
phoenixorion
One thing I noticed: when I select the not active option in Lin_variante_szl, the indicator still functions as long as I push/pull the stalk. It goes off when I release it. I tried with many options but the behavior is the same. The lane change blinks 3 times but after the threshold it only blinks as long as I hold the stalk in the position.
      09-04-2023, 08:58 AM   #20
TheNine90
578
Drives: bmw
What options are available on the list.
What component did you replace exactly? do you have part number?
      09-04-2023, 09:01 AM   #21
phoenixorion
The part is LZ 9 351 140-02 10112143-02. All the options with szl_us has r. For eg szl_us_r_aic.
      09-04-2023, 09:03 AM   #22
phoenixorion
The options are szl_us_r, _4Band, aic, aic_4Band, aic_4Band_fla, aic_fla etc. I tried all the options but the functionality is the same.
1addicts
