Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Strange chirping when braking sometimes (video)
      09-16-2020, 02:43 AM   #1
chewable
Drives: 2011 BMW 328i e90
Hey guys,
I've noticed that my 2011 e90 has this chirping sound about 75% of the time when braking. It also doesn't make the sound reliably during the entire time I'm braking, probably once I slow past down to 10 to 5 mph. It doesn't happen if I'm not braking and is worse if i brake hard.
This is a video of it: https://photos.app.goo.gl/f6Wsz2odQYLThsFB9
Its a little hard to hear in the video but it is louder in person
I've been reading around and some have suggested it was brakes without anti-squeal paste, so I changed my brakes today but still squeals. Others have suggested it had to do with the hand brake, but the sounds are coming from my front, not rear. Others have suggested its my drive belt or front crankcase seal, but why would it only happen when braking? I'm not sure but it is very annoying. I'd appreciate any insight in where to begin diagnosis.
      11-06-2020, 10:08 PM   #2
chewable
Can anyone help me?
      11-07-2020, 07:05 PM   #3
Emilime75
1209
Drives: 2010 335i E92 LeMans Blue
That's the car telling you to activate your turn signal BEFORE you get to the turning lane and come to a complete stop.
      11-08-2020, 09:54 AM   #4
e91Owner
e91Owner
425
Drives: 2011 e91 & 2010 e60
Originally Posted by chewable View Post
Hey guys,
It does sound like a tensioner or belt squeal. If you haven't replaced yours... it's certainly easy and not that expensive. But this is just a throwing parts at your car solution.
      11-09-2020, 04:56 PM   #5
chewable
i have the parts on the way and will try that. but wouldn't you expect the squeal to occur at all times? not just when i'm braking?
      11-09-2020, 09:54 PM   #6
cliffschum
16
Drives: 2006 330
I'd spray the belt with conditioner first, before replacing. Lubricate the tensioner too.
      11-10-2020, 03:33 AM   #7
Jurciks
58
Drives: BMW E91 325i
Try to turn off A/C (heater) and then try to brake.
      11-10-2020, 11:30 PM   #8
chewable
Ill try spraying the belt down first. It looks in good condition but has not been replaced at 87000 miles so will try and report back. Ill likely replace it anyway since its due.
It happens whether or not the ac/heater is on.
      11-11-2020, 12:34 AM   #9
e91Owner
e91Owner
425
Can't really explain that since the brakes boost from vacuum like most cars. I'm just commenting on the sound. It could be that since the engine is also decelerating when you are braking that they just happen to be coincidental. Have you tried revving the engine in neutral to see if the sounds follow?
      11-11-2020, 01:41 AM   #10
Jurciks
58
I have a similar sound when braking, but it disappears when i turn my A/C (heater) off.
