09-11-2020, 01:49 PM | #1 |
166
Rep 198
Hi all, I would love some advice troubleshooting this issue as I am not too experienced with electronics. Providing all information because I am not sure what is relevant and what is not-
Yesterday there was a huge storm in DC metro area which I got caught up in in my commute. Some standing water on highway but nothing crazy. Very heavy rain. Parked car, started it up 4 hrs later. 10 minutes into commute home I herd an audible zap noise followed by the iDrive system rebooting. After this iDrive showed "loading" when trying to reconnect to Bluetooth and USB. Nav screen stuck on "loading Navigation System". Radio works fine. Tried AUX connection and audio only plays through speakers on left half of car (may just be my AUX cable IDK).. fast forward.. Read codes through MHD platform- Cat underperforming (standard, I have hi flow cat), and O2 sensor short circuit (never seen this before, not sure if it's relevant or not). Browsed forum. Tried resetting the iDrive via locking car for a few hours and through reflashing ECU. Every time the iDrive system boots for the first time there is an audible almost clicking type noise coming from box located under iDrive display beneath AC controls. Clicking noise only occurs when iDrive initially boots. Pulled up fuse diagram and I see a good number of fuses in the box under the hood are dedicated to the front control unit. I have never tested or replaced a fuse before in any of my vehicles. Really praying it's just a fuse and not an iDrive replacement. What would be your next recommended step for troubleshooting? Get voltmeter and check fuses? Or pull each fuse out and visually inspect? The diagram I sourced shows fuses 25, 120, 121, 122, 123, 125, 126, 128, 142, 147, 155, 159 from engine bay fuse box all dedicated to the control unit. I can also provide a video of the audible clicking on iDrive boot if that would be of assistance. Thank you so much for your help!
| 2020 X3M | 2015 335 | IG & YT: @straight6kris | 335 Build Thread: https://f30.bimmerpost.com/forums/sh...4#post27268174 |
09-15-2020, 05:44 AM | #2 |
BimmerPost Supporting Vendor
668
Rep 1,980
Drives: 2020 G20 320i M Sport
Sounds like the hard drive has gone bad in the iDrive unit judging by the click sound and maps not loading.
If this was a fuse issue, you wouldn't see the head unit turn on let alone display so I'd say your best bet now would be look into getting it replaced with a used one.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
09-16-2020, 04:34 PM | #3 | |
166
Rep 198
09-16-2020, 05:12 PM | #4 | |
166
Rep 198
Other people are talking about a combox replacement/repair, do you think that could be the issue or do you think a idrive replacement is more of what I'm looking at? Thanks for the help. |
09-16-2020, 10:24 PM | #5 | |
668
Rep 1,980
Just replace the iDrive receiver and that will resolve the issue but keep in mind that you will coding and activation for Nav, Voice Control and Sirius XM to work again and we can help with that.
S6K166.00 |
09-16-2020, 10:28 PM | #6 | ||
166
Rep 198
09-17-2020, 11:12 AM | #7 |
668
Rep 1,980
Are you referring to the 2015 335i M sport on your profile? BMWs from model year 2015+ would not have comboxes.
09-17-2020, 06:01 PM | #8 | |
166
Rep 198
09-18-2020, 10:11 AM | #9 |
668
Rep 1,980
That is a TCB which strictly only handles telematics. A combox would not be part of your configuration given the model year and vehicle options you have.
09-18-2020, 10:12 AM | #10 | |
166
Rep 198
steve@codemybimmer667.50 |
