Maintenance difficulty levels
09-05-2020, 02:23 PM | #1 |
Rep 3
Dealership recommended that I perform these services but I'm not about to spend ~4500 if I am able to do them myself and save money.
I was wondering how hard/easy these are DIY and the prices. 2011 E90 328i 74k miles. |
09-05-2020, 05:35 PM | #2 |
General
17315
Rep 18,737
All those are "search the internet jobs". Inspect the engine and verify you have oil leaks. Use a bright LED flashlight. For the serp belt/ tensioner, check if the belt is over the lip of the tensioner pulley.
To answer the level of difficulty, what is your level of experience and what kind of tool set do you have? There are DIYs on all of those in the DIY subforum. You can read the procedures and make up your own mind. Last edited by Efthreeoh; 09-05-2020 at 08:08 PM.. |
09-06-2020, 12:47 AM | #3 |
e91Owner
425
Rep 1,129
Placing these in the order of easiest to hardest:
Wiper blades: $25 Oil filter housing gasket: $11 Can of refrigerant & hose: $20 Tensioner, idler pulley & belt: $76 (I'm assuming they mean valve cover) Valve cover & gaskets: $600 Oil Pain gasket and bolts: $60 That's assuming you have all of the tools for the job and the know-how to do them. As mentioned before, there are plenty of DIY guides for all of these on the forums and YouTube to gauge your interest in doing them yourself. That's the cheapest oil change I've ever seen, BTW. I can't even get the oil for that price from walmart. |
09-06-2020, 06:25 AM | #4 | |
General
17315
Rep 18,737
You have that correct. LOL
09-06-2020, 06:43 AM | #5 | |
General
17315
Rep 18,737
OP, all of these repairs are very difficult if you have no wrenching experience and a deficient tool set. I'll assume that you don't have the tools or wrenching experience because your 1st post on the Forum is asking how hard the DIYs are. That tells us that you got such an inspection report from the dealer because he recognizes you have little experience with BMWs or maybe even automobiles and will run to the internet in search of answers. He's expecting you to find the valve cover gasket, oil pan gasket, and oil filter housing gasket all to be common issues with the N52 E90 and hopes you'll be nervous about it and have him perform all the work; that's what I meant about search the internet jobs. The oil pan gasket and valve cover gasket are complex jobs that an experienced home auto mechanic would not ask about how difficult they are, he'd just go research the DIY videos and/or instructions found on the internet and see if he needs any special tools. I'd say simply that if you don't have a floor jack and four jack stands to safely lift and support the car to work on it, you are not prepared to accomplish these several repairs. If you have the wrenching experience to do such repairs, you'd already have a floor jack and jack stands because you've done other repairs on a car that required such equipment.
09-06-2020, 07:48 AM | #7 |
General
17315
Rep 18,737
I understood (and agree - a filter is $10 alone). My point was the $37.50 was loss-leader to get the OP to fork over $4,500 for what might be unnecessary work (at 74,000 miles). i.e. a $4,500 "oil change"
09-06-2020, 08:07 AM | #8 |
31
Rep 131
$463 to replace the belt tensioner?! That's a 10 minute job that anyone could do. Plus half of the jobs probably don't actually need doing yet. Definitely DIY them, you might need to find an indy for the oil pan (if it is actually leaking oil) but the rest are doable by an amateur (speaking from experience).
09-06-2020, 04:23 PM | #9 |
3537
Rep 3,049
At least his first post wasn’t about 19” wheels, driving lights or bolt on mods. I would buy a basic tool kit, floor jack and jack stands while reading the DIY tutorials. You will learn a lot, save a lot and take pride in your car instead of just paying a mechanics bill.
09-07-2020, 08:13 AM | #10 | |
General
17315
Rep 18,737
09-08-2020, 11:12 AM | #11 | |
31
Rep 131
Ok I may have done it whilst doing my OFHG but I'm sure they're also smart enough not to put the airbox back on after each job. Let's call it 20 minutes as a standalone job, 30 minutes maybe if you forgot which way round the belt goes. |
09-08-2020, 12:08 PM | #12 | |
General
17315
Rep 18,737
Just being realistic.
09-08-2020, 12:24 PM | #13 |
37
Rep 98
Been there before! Usually find out which tool I'm missing mid job and order on Amazon next day. Crack on
Most those jobs are not too hard just time consuming if you haven't done them before. Take your time, most can be accomplished with this forum and YouTube as guides. Only ones I havent done there are oil pan and valve cover. Oil pan I see is a bastard due to having to remove the sub frame, but valve cover looks feasible albeit quite involved for a home mechanic. Agree with tcphoto, if you are keen on getting more wrenching experience, buy some basic kit and enjoy the challenge. If you are just trying to save cash, you are likely to get frustrated doing these and pay for someone else anyway. I. That case just get some comparative quotes. |
09-08-2020, 12:55 PM | #14 | |
31
Rep 131
I would say start with the belt and if you manage to mess that up then maybe take it to a professional. Otherwise enjoy learning and try not to snap too many bolts or crack too many hoses. |
Efthreeoh17315.00 |
10-01-2020, 12:46 PM | #15 |
Rep 1
That oil pan gasket is gonna be your hardest job. That involves dropping the subframe. My mothers E93 has that problem right now, so Im just monitoring the oil level until finances return to normal.
To add some info, I have replaced the valve cover and gasket on the E93 before. It is doable, but it will be frustrating for inexperienced mechanics. Dont be discouraged. Theres a good video by FCP Euro about doing the work. It will take a bit of finesse but it IS doable. Just be patient and be carefully stubborn. Last edited by Indianb0y017; 10-01-2020 at 12:49 PM.. Reason: Added info |
10-02-2020, 10:06 AM | #16 |
General
17315
Rep 18,737
I just want to make it clear, oil leaks on the N52 do not have a material effect on oil loss. As they age, N52s just start to consume oil, which is lost to the combustion process. One of my N52s has very high miles on it and when I replaced the pan gasket at 290,000 miles after about 90,000 miles of leaking, there was no discernable reduction in oil loss once the new gasket was in place. Likewise for the OFHG and VCG.
Small oil leaks on any engine make for a big mess, so it looks like a lot of oil is leaking from the engine, but actually there is very little. My high-mileage N52 has no oil leaks at the moment and consumes about a liter of oil every 2,500 miles (6 - 8 weeks time for me). My lower-milage N52 (107K), consumes about 1/4 Liter every 7,500 miles. |
Phil325i615.50 cliffschum15.50 |
10-02-2020, 10:18 PM | #17 | |
Rep 6
Drives: E90 328i
10-02-2020, 10:47 PM | #18 |
Rep 6
Drives: E90 328i
At least the $900 for OFHG + Belt and Tensioner is cheap compared to the $1800 my dealer charged me a few years ago. That was the repair that convinced me to go DIY if I intended to keep my car indefinitely. I've been doing so for the last 100K miles. It still runs great at 262K miles currently. It has a VCG leak which I've been meaning to get to. With the oil leak, it needs 1L added oil after 7000 miles.
10-03-2020, 07:34 AM | #19 | |
General
17315
Rep 18,737
10-05-2020, 10:43 PM | #20 | |
1436
Rep 2,526
Drives: 2011 328i Wagon
Out of curiosity, why remove the cooling fan? I've done the tensioner on both my 128i and 328i, (128i a week ago) and there is all the room in the world to do it. Just need the intake piping out of the way. I do agree with the need to be darned careful with that aluminum bolt though! But I am not sure that a beam torque wrench makes much difference with a low torque figure then an angle specification. 18ft/lbs then 90 degrees.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
10-06-2020, 05:38 AM | #21 | |
General
17315
Rep 18,737
cliffschum15.50 |
10-08-2020, 02:48 PM | #22 | |
3973
Rep 7,215
I also used a click type torque wrench, lol. but, I do have a pretty good understanding of how TTY bolts work and no, spending $1500 to replace an OPG on a $4500 car is not worth it, unless it's at Exxon Valdez levels of leaking. |
