How do VANOS solenoids age? When to replace?
09-05-2020, 09:35 AM | #1 |
213
Rep 211
So last week I cleaned my N52's VANOS check valves, one was filthy. Got a lot more power between 3-4k miles.
Today my new VANOS solenoid O-rings finally arrived so I've removed and cleaned them. They didn't seem dirty but got a good dose of MAF cleaner anyway (I also cleaned the MAF). I applied 9V to the terminals and they clicked cleanly and opened about 1mm. I'd swear one moves more than the other but hard to tell. When these die is it a case of total failure or do they degrade over time? I'm chasing a lack of low down power basically. Done a major service and replaced the usual bits but it still seems weaker than it should be under 3500.
www.unixnerd.co.uk - providing Nerdy BMW stuff since 1996!
09-05-2020, 10:34 AM | #2 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Rather than replace the solenoids I would first check/clean/replace the VANOS filters. Part No. 11367507729 (you'll need two).
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
09-05-2020, 11:46 AM | #3 |
213
Rep 211
Did that last week, one clean one filthy. Good a good bit more oomph. Just had a wee drive after cleaning the solenoids and it's made a small difference. Cleaning the filters really made a big difference.
09-09-2020, 12:10 PM | #4 | |
Rep 6
09-09-2020, 12:49 PM | #5 |
213
Rep 211
Previous owners weren't very good at changing oil, it came out black. Solenoids seem OK since I cleaned them and they click very positively when I apply a battery. I just wondered if there was any point in replacing them. Is the failure mode that they just gum up and die or do they gradually open less with age?
