08-28-2020, 01:51 PM | #1 |
25
Rep 71
Rattle from window / door area
Hi Guys
I have a super annoying rattle from window / door area, unfortunately I can’t see any way to upload a video here. I’ve had 3 dealerships visits and so far it’s not been corrected, it’s from any speed on uneven roads. It’s a clicking / rattle. I’ve had Door Pin secured, new window frame seals and the B pillar shadow line gross trim readjusted. All this has not made a blind bit of difference, anyone have any other ideas what could be causing it ? The only other thing that’s happened to this door was the seal along the bottom came away and has been replaced twice so far. Which surprises me as it’s the passager door and mostly I drive alone. I have also put that gummy pledge on all the doors seals. |
08-28-2020, 09:20 PM | #2 |
17
Rep 30
Check the sunroof. I had a similar rattle that sounded like it was coming from the passenger door/seat. Turns out it was the sunroof seal. It would rattle with the shade open but not with it closed.
08-29-2020, 06:26 AM | #3 | |
181
Rep 546
540iSUP704.00 |
08-30-2020, 03:53 PM | #4 |
25
Rep 71
No sun roof on my car guys, so something else any ideas guys ? I actually hate driving my G30 now cause of it, even with my H&K sound system at 50% volume I can still hear the dam rattle every second of the drive.
08-31-2020, 03:57 PM | #5 |
12
Rep 49
Drives: 2018 BMW 540i xDrive
I had a really annoying rattle from the roof area and it was coming from the dome light. There was a missing bolt and it was replaced. Rattle is gone. Hope this helps.
07-24-2022, 04:22 PM | #6 | |
25
Rep 71
07-24-2022, 11:17 PM | #7 | ||
5691
Rep 4,628
Drives: BMW M550i xDrive (2020)
2020 M550i xDrive (Champagne Quartz/Black)
2021 X7 40i M-Sport (Arctic Gray/Tartufo) RETIRED: 2018 540i Luxury Line (Dark Graphite/Canberra Beige) |
07-25-2022, 10:23 AM | #9 | |
256
Rep 390
Drives: 2021 G30 M550i
07-25-2022, 01:25 PM | #10 | |
4528
Rep 5,382
MelbourneFinn256.00 |
07-25-2022, 03:51 PM | #11 | |
25
Rep 71
Before gumfledge there was a mild slightly annoying rattle over bumps, after using it .. it rattled non stop on flat roads, I was seriously considering selling the car, it got that bad. I have to use the silicone remover every 6 -9 months or so, but it’s gone each time, funny thing is.. it only effects one door. But this is the stuff https://www.schmiedmann.co.uk/en/pro...3-12-2-298-199 I posted it on the F44 forum [wifes] and a few boys already used it and it’s cured their door and boot creaking. There is also a you tube video (BMW mini) about a guy that was trying to solve door rattle for months and once he used it, boom silent again and the gumfledge made his worse too. I use BMW gumfledge on my G30 boot rubbers, without issue thou. Plus 1000s of posts on the F30 owners forum with this issue, and all warning NOT to use gumfledge in fact Dealerships was installing special clear stick on M3 tape on the door frames to help. |
07-25-2022, 06:13 PM | #12 |
81
Rep 179
Thanks for sharing! I sure will be saving this info in case rattles show up, I would be mad too. Actually one of the stronger points in this car for me is that it is rattle free.
07-26-2022, 05:52 AM | #13 |
7439
Rep 6,814
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
I am sure you checked the passenger seatbelt buckle rattle on the B pillar. Just throwing it out there.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
07-27-2022, 04:17 PM | #14 | |
25
Rep 71
The issue was silicone / car wax on the rubber door seals, causing the doors rod flex and rattle when moving. Last edited by Jonny2400; 07-27-2022 at 04:39 PM.. |
07-27-2022, 05:04 PM | #15 |
630
Rep 433
this was driving me up the wall earlier this year.
in my case, it turned out to be the rear top light after the emergency call battery was replaced. i haven't heard that noise recently - if i'm going deaf, hey it's worth it, i'll never hear that damn noise again... |
07-28-2022, 05:28 AM | #16 | ||
7439
Rep 6,814
The issue with leaving it plugged in is that when you stop the car, the radio plays for a long time unless you lock it. I don't want to have to get into the habit of unbuckling the passenger side every time I stop.
