08-14-2020, 10:58 AM | #1 |
122
Rep 278
A sad incident with my M2
Yesterday I took a day off and drove to my favorite twisty road. On the first minute, I suddenly heard a sound of something that got hit. At first I thought it is a stone that had been thrown on the car's body from the wheel or something like that. Then. when I have tried to go back on the road, the engine did a strong sound, I heard the turbo whistling hard and the car didn't have power.
I started thinking what to do. The service is 40-50 KMs from here. I didn't know what's wrong and it'll be effected if I'll keep on driving so I stopped on the side of the road and ordered a tow truck. It took them 4.5 hours to get there The service isn't working on Fridays so I'll need to wait till Sunday to know what went wrong. After asking some people it seems like one of the turbo's pipes loosened up or was blown. I'll update on Sunday |
08-14-2020, 11:04 AM | #2 |
266
Rep 307
Charge pipe could've blown too. I experienced loss of power when my CP blew. Pop the hood and see if the pipe blew.
Mark2016MG48.00 |
08-14-2020, 11:14 AM | #3 |
6638
Rep 4,145
Drives: '18 M2 6MT
Fingers crossed it's the charge-pipe, which is no big deal at all.
08-14-2020, 12:21 PM | #4 |
122
Rep 278
Thanks
The tow truck towed the car to a night parking and I'll see it again only on Sunday morning but then it'll be in the service so they'll let me know if it is a CP. Anyhow, the car is still under warranty so whatever it is, I will not need to pay for the damage. The only thing is if it is a broken turbo, it might take a few weeks to fix. |
08-14-2020, 12:25 PM | #5 | |
Luxury at the redline :)
9105
Rep 7,563
https://www.bimmerpost.com/forums/sh...php?p=26435135 |
kingikra121.50 BallHog5873174.50 |
08-14-2020, 12:35 PM | #6 |
6638
Rep 4,145
Drives: '18 M2 6MT
08-14-2020, 12:49 PM | #7 |
477
Rep 683
I blew my charge pipe a bit more than a week back. It DOES make a loud CLANK! sound. It's real obvious if you can look at the engine. The black pipe on the port side of the engine (not saying drivers side, as not sure which side they do where you live, so nautical terms) blows up right where it hooks to the throttle body\intake.
Bet you got the check engine light with a bunch of ugly codes that should stay gone once the pipe is replaced. Easy fix for the dealer and hopefully they have the part in stock. They very well may as it's a common failure with an N55. Good luck. 4 hours at my dealer and I'm back in business.
2004 E46 ///M3 SMG Convertible Carbon Blk\Imola
2017 LBB ///M2 DCT 2013 Porsche Boxster S |
08-14-2020, 03:27 PM | #8 | |
122
Rep 278
They should have this part at the service. Back then, I had a Cadi ATS-V which cost 140000 USD. It is very cheap for a car like this here. A gear oil pipe has been damaged and it took two and a half weeks to get one. A new M2 comp costs here 176000 usd so I assume they have one in stock |
08-15-2020, 09:25 AM | #9 | |
388
Rep 1,660
08-15-2020, 12:16 PM | #10 |
122
Rep 278
BTW, I think that I have another issue which I can't let the service check and I'll explain why :-)
Lately, when driving in speeds that are above 100 MPH (100-125) I feel like the car isn't stable as it was before. The maximum speed I got with the car before was 155 MPH and it was very stable. The maximum speed limit on the highways here is 80 so they cannot check that issue in the service. Can one of you point me to something that can be the reason? I'll add that after my last track day I have replaced both front brakes and pads and replaced both my rear tires to something cheap but IIRC, this issue was with the old PS4 as well. It is obviously has nothing to do with the pipe. That's for sure :-) |
08-15-2020, 12:33 PM | #11 |
6638
Rep 4,145
Drives: '18 M2 6MT
You're going to have to describe in detail "isn't as stable." Could be something a simple as the tire pressure, tire wear, or the surface you're driving on.
08-15-2020, 02:42 PM | #12 |
122
Rep 278
That won't be easy to describe in details. As For the reasons you've mentioned, surface is not the same so it's not the issue. As I mentioned, I've replaced both rear tires a month ago. What I haven't replaced is the front tires which haven't been replaced since I bought the car in February 2019 and they also worked hard on the track. Can they be the problem?
08-15-2020, 03:23 PM | #13 | |
464
Rep 484
If problem continues, and still under warranty, why not take it to the BMW dealer to have them take a look? Dealer and warranty should not have any issues with a car that has been driven at high speed in a "driver's education event". |
kingikra121.50 |
08-15-2020, 04:09 PM | #14 | |
2532
Rep 825
OP, I had the EXACT same issue with regard to stability and changing tires. Here's what happened to me, and what I did to fix the issue. If it's the same for you, then the good news is that this is a VERY, VERY, VERY simple fix. 1. I replaced both rear tires, and immediately afterward, my M2 no longer felt "stable" at high speeds - it felt as though I would have to constantly fight to keep the car moving in a straight line 2. I then read this article from Tirerack: https://www.tirerack.com/tires/tiret....jsp?techid=47 3. The instability I was experiencing at high speeds was due to tramlining. As the Tirerack article points out, when tires are worn down, they "become more responsive as their tread depth wears away (which is why tires are shaved for competition and track use), a tire will become more likely to tramline as it wears" 4. Moreover, the problem becomes worse the higher your tires are inflated: "Using higher tire pressures than recommended by the vehicle manufacturer for your driving conditions will unnecessarily stiffen the tire and make it even more willing to cause tramlining" 5. Given all this, I realized that here's what had happened with my M2: a) My tire pressures had naturally fallen down to ~30 PSI over time. As my tires wore down, I never experienced any tramlining, because at the same time, the tires' PSI had also fallen. b) When I had my rear tires replaced, the tire shop inflated all 4 tires back to factory recommended 35 PSI. c) I still had my old, worn front tires on my M2, like you, so now the old, worn front tires were tramlining like crazy at 35 PSI. I simply let out 4 PSI from each of my tires (I'm now down to 31 PSI), and the car drives like it should - no more tramlining. Feels perfect again. Hope that helps, OP. If it's the same issue, it's a super, super easy fix. Best of luck to you! |
08-15-2020, 04:26 PM | #15 |
217
Rep 289
What CaptObvious said. In addition, mixing tire compounds is really not a good idea. They will work differently, heat differently, gain and lose traction differently, become sticky or greasy differently. It's honestly not worth the savings to mix them.
///M2 - 2018 LBB DCT
cptobvious2531.50 |
08-15-2020, 05:24 PM | #16 | ||
9105
Rep 7,563
Point is, different tires equal a different feel - for better or worst. On the same principle, I've notice a dramatic difference when going from a heavier to lighter wheels. The wheels and tires are intricate to the feel and handling of these vehicles.. |
Fabb228.50 |
08-16-2020, 02:43 AM | #17 |
122
Rep 278
Thanks all. The car had been towed to the service this morning. The service guy had called and told me that it is, indeed, a turbo pipe. He sent a picture. For some reason, they claim that it is not under warranty but they are checking. What do you guys think?
I've also told him about the instability issue and he also claims that it could easily be the worn front tires or even the cheap rear tires. CaptObvious, thanks for the detailed explanation. I'll try that for sure after I'll get back my car. Larry, you're saying it is not worse the saving but then again how much a pair of Michelin costs at your end of the globe? Here they are 900 usd. I paid for the cheap ones less than 400. I'll just add up that the car is already under a trade deal. I've replaced it with a cayman s that should arrive at December or January 2021. |
08-16-2020, 05:56 AM | #18 | |
9105
Rep 7,563
My warranty expired but I got my auto insurance company to pay for it, under a mechanical breakdown rider coverage I opted for, which cost about them about $900, so you better hope your dealer do indeed absorb the cost, under the factory coverage. Also, BMW recently revised the charge pipe, enhancing the lip, which is know prone weak area, so it shouldn't explode a second time around. |
08-16-2020, 06:35 AM | #19 |
122
Rep 278
Yes... Indeed it is under warranty. Why have they claim it is not? Maybe the "success method" (I'll tell the customer that it is not under warranty and charge him for that unless he'll claim it is under warranty)?
Hopefully I'll get the car back today. The part got there at 13:30 and they are closing at 16:30, should be enough I presume. Thanks for the pictures. Hopefully it'll not be damaged again with that enhancement. |
08-16-2020, 06:52 AM | #20 | |
23
Rep 27
Worst case scenario, you contact corporate and they'll clear it up for you if the dealer doesn't play ball. In my case thats BMW Dubai/ME. I'm not sure if Israel falls under their corporate umbrella. There aren't many laws protecting the consumer in our case. Stuff like the Magnuson Act aren't applicable here, they'll just keep fixing a lemon til its out of warranty (and their hair). |
08-16-2020, 07:02 AM | #21 | |
122
Rep 278
Israel and UAE has just signed a normalization deal a few days ago so it can't be in Dubai. As much as I know, in these cases, I need to point the claim directly to Germany. Fortunately they have saved me the hassle. Thanks! |
08-16-2020, 12:53 PM | #22 |
122
Rep 278
Went to pick my car back a few hours ago. Seems like the turbo pipe issue is behind me.
I'll start to debug the instability issue this weekend (Almost not driving at all during week days now with the Corona). I don't think they have done/checked anything in the service concerning this issue. What I did fill driving back home is when stopping from high speed, the car is pulling a bit to the side. This, indeed, can be caused by the old front tires. |
