Wipers won't turn off, Speedometer not working, dash lights - E90 320d
08-05-2020, 09:24 AM | #1 | |
Rep 4
Hey guys,
My 2007 E90 320d recently lit up like a christmas tree. This happened about a week ago and it was during a cold start early morning. The red handbrake light stays on, airbag light, seatbelt light, DSC and ABS. Along with this the wipers are on and cannot be turned off as well as the speedometer not working? The fuel gauge also moves about erratically but usually reads correctly, just sometimes drops up and down. This is all new with this problem. My first thought was to check on a few forums to see if I could find anyone else with a similar problem. Steps I have taken so far to try diagnose / repair the issue.
Am i right in thinking that this would either be a speed sensor issue on a different wheel? I read on a different post that if the brakelight was red it'd point me to the direction of the rear wheels. If not a speed sensor issue my other thought is that this is a DSC issue, potentially the module? Really I'm looking for any guidance on what people would suggest checking as opposed to getting it down to a specialist. Any thoughts lads? |
08-05-2020, 01:39 PM | #2 |
242
Rep 1,354
You may want to search for "wipers not shutting off" here.
There was a whole thread about this symptom that turned out to be due to a fuse in the engine bay that is normally overlooked. |
08-07-2020, 03:00 PM | #3 | |
Rep 4
Really starting to scratch my head at this Thanks either way for the suggestion! |
02-18-2022, 01:22 AM | #5 |
Rep 4
Hey. To end this thread. Found the solution. It was a combination of two fuses gone at the same time. Found it with a mechanic friend and he was as baffled as I was. Once we changed them it worked fine and hasn’t gone again since. Can’t even think of the chances of two fuses blowing at the same time and it not being some issue that repeats.
Newkidontheblog0.00 |
11-16-2023, 07:29 PM | #7 | |
Rep 1
Not helpful at all!!!!!!
