07-30-2020, 08:31 AM | #1 |
Rep 2
Best Oil for 340i with Software
Apologies if this has been discussed to the far ends of the earth. I did find a thread but am unable to re-locate it now. Was there some opinion on tuned 340i B58s and NOT using the recommended BMW oil ? Anyone with a tuned 340 using the BMW recommended or a different weight ?
07-30-2020, 09:40 PM | #2 | |
3629
Rep 10,393
This dealer oil is also affordable. http://pqiadata.org/BMW_5W30.html Below is a tool which allows you to compare OEM spec's (ex LL01 vs LL01FE). https://online.lubrizol.com/relperftool/pc.html
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
thefatstig1.50 |
07-31-2020, 10:17 AM | #3 | |
Rep 2
F32Fleet3629.00 |
07-31-2020, 11:06 AM | #4 |
277
Rep 501
Personally, I don't think oil weight is as important as you shorting the intervals due to potential issues like fuel dilution.
Do 5,000-7,500mi instead of 10,000mi. Go up in weight if you find your oil is overheating, otherwise it should be fine as-is. Last edited by AspektUSA; 07-31-2020 at 11:15 AM.. |
sspade2468.50 |
08-03-2020, 05:53 PM | #5 |
95
Rep 116
Agreed, I feel like shorter intervals are more important than the oil you use.
That being said, I use shell 5w40 diesel oil. Was skeptical at first, but heard good things from everyone that uses it. 5k miles in and no issues, I feel like it made the engine quieter and smoother, but that could just be in my head. And 20 bucks a gallon |
08-04-2020, 08:25 AM | #6 | |
3629
Rep 10,393
08-04-2020, 12:34 PM | #7 | ||
95
Rep 116
08-04-2020, 01:24 PM | #9 | |||
3629
Rep 10,393
The thing is that ZDDP isn't the only game in town and there are families or organic additives which don't show up in an UOA. Same goes for visocity index improvers. HDEO's use different types. Best case is to shop OE certs. Porsche/VW, Mercedes Benz, and BMW. More certs an oil has the more likely it's a high quality product. Besides lubricant failures are almost a thing of the past. If it happens it's going to be poor engineering and no oil will stop that. On a side note. The absolute worst thing is to do is choose an oil because it's advertised as "exceeding xyz". Exceeding to not equate to better when it comes to the performance of motor oil. It's just advertising.
