07-25-2020, 10:12 PM | #1 |
Rep 40
Caliper covers? Yay or nay
I love the look of the blue m calipers but sadly my car doesn't have them. Is it too tacky to paint/ get covers for them?
07-26-2020, 12:55 AM | #3 |
1599
Rep 3,748
07-26-2020, 01:27 AM | #4 |
10
Rep 81
07-26-2020, 01:37 AM | #5 |
516
Rep 749
Drives: F31 320d xDrive M Sport
Caliper covers are tacky and cheap imo.
If you don't want to upgrade to the M Sport/Performance Brembo kits, then you've got 2 options. Powder coat (although the calipers will need rebuilding as well with new seals, and probably end up costing quite a bit, maybe not as much as used Brembo calipers) Painting them. On my old cars I always used to paint the calipers with Hammerite (other direct-onto-rust straight-to-metal paints are available, as are brake caliper paints which are probably the same). Some colours look better painted than others, and depending on the wheels they can be quite exposed or quite hidden, so bear that in mind. That is the cheapest option though and only requires you to take the wheel off... if you're careful you can paint whilst the brakes are all on the car. Maybe undo the caliper bolts to remove it off the brake disc at least.
07-26-2020, 03:01 AM | #6 |
Great Teacher
1120
Rep 1,314
Drives: 06 e91 325ix
No on covers, yes on paint, but only if you don’t have single piston brakes...
and if you do, I would recommend to go only black or silver paint.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
07-26-2020, 10:10 AM | #7 | |
1599
Rep 3,748
Let him paint the brakes. It's better than those plastic mopar cover. The OP just have to paint them right...paint the caliper... not then clips that has bmw engraved (keep those unpainted) |
07-26-2020, 10:35 AM | #8 | ||
993
Rep 1,934
g30 for eg https://www.ebay.com/itm/303605729836
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
07-26-2020, 02:53 PM | #9 |
5913
Rep 10,288
It's your car after all and your decision is the only one that matters.
With that mind, caliper covers do not even approach to serve the intended purpose of suggesting the presence of large calipers. So easy to tell otherwise. I suggest to get M Performance brake kit. |
07-31-2020, 02:10 AM | #10 |
28
Rep 161
Drives: 2008 335i Manual
Don’t get caliper covers, there’s videos on YouTube of them CATCHING ON FIRE. Very dangerous.
If you do paint your calipers i suggest the G2 ceramic paint kit from Amazon. It’s a brush on not rattle can; and its some sort of ceramic paint. I put on 4 layers and holy shit it’s a thick paint. I think its honestly equivalent to powder coating. It’s self leveling so it came out super slick and the paint is thick. I changed my brake pads recently and had to take out the spring clip and used a metal screwdriver. Didn’t scratch thru the paint. Just a slight scratch which could be seen as wear n tear. Also highly recommend taking the calipers off. I hung them off the springs at first but it was too difficult to get on my back and paint all around. Take them off and get a brake bleed stopper kit on amazon so you don’t drip fluid. Then clean the shit out of them. I used 1 can of brakekleen per caliper and a steel brush. Mask off the rubber boots and bleeder valve. Also the paint brush in the g2 kit is kinda garbage the brush flakes off luckily i had a nice set from my wife that i could use. Do light coats of course so it doesn’t pool up. |
07-31-2020, 07:52 AM | #11 |
Great Teacher
1120
Rep 1,314
VHT High heat caliper Paint covers very well and very quickly, looks nice but stockish. Used it as a base color on mine last night.
07-31-2020, 10:28 AM | #12 |
8276
Rep 16,139
I paint mine in the original silver color with PlastiKote caliper paint. It's easy, you don't even need to pull them off the car, and it's easy to redo them when they start to look ratty again. I do the same with the hubs. https://billfitzmaurice.info/images/BMW/Rear Wheel.jpg
