TPMS Mounting Brackets (no holes needed to be drilled!)
09-25-2008, 03:15 PM | #1 |
76
Rep 579
I was originally given the idea about drilling the wheel to accomodate the TPMS sensor (since putting the TPMS sensor in the current valve stem area will not allow it to sit flush), though I couldn't find a local shop that would be willing to drill.
Did a bit a research, and found that there are alternatives to drilling, and the kit was only 60 bucks. Here is the link for it, http://029d716.netsolstores.com/tpmsstrapkit.aspx You can also buy just the mounting bracket or just the steel strap seperately. I ordered them today and will get them in sometime next week, so I'll take pictures of the install and then post them back up here. It seems to be a pretty good idea, not sure if this is a repost or not, but I couldn't find anything like this on this forum. I'll keep ya guys updated. |
09-25-2008, 03:36 PM | #2 |
Rep 207
I am going to get my new wheels put on today and was told that they could simply remove the TPMS from the OEM wheels and fit them to the new wheels.... is this not true?
09-25-2008, 03:59 PM | #3 |
76
Rep 579
its true for wheels that dont have oddly mounted valve stem openings, such as 2/3 piece wheels
on my CSL reps, they fit just fine, for my new set of DPEs they will not work as I'm told, so I went with this strap |
09-25-2008, 05:18 PM | #5 |
3573
Rep 9,788
09-25-2008, 06:24 PM | #6 |
76
Rep 579
10-03-2008, 03:31 PM | #8 |
76
Rep 579
bought straps, ended up not using them, got the holes drilled instead, goin to the shop to check it out after i get off work in an hour, ill sell the straps to you -20 bucks of what i paid if you want them, but i ended up drilling
10-05-2008, 03:10 AM | #9 |
100
Rep 2,528
Drives: 95 Avus M3 and 07 E90 Fam Car!
I don't get it, I've never seen those TPMS strap things? I do understand 3pc wheels will need an adapter for the TPMS but when I have installed 3pc wheels I just install the TPMS on the inside barrel and attach an extended valve.
10-05-2008, 11:47 PM | #11 |
76
Rep 579
strap is similar, but you strap the tpms onto the strap, which straps onto the wheel center, yea i got mine drilled in the long run, much better...now i got a rubbing problem to deal with on my fitment
10-11-2008, 01:16 PM | #12 |
60
Rep 804
i guess it depends what wheels you have. some have it set up for tpms and some dont.
i have a set thatll ill let go for 50 shipped that i bought from themodcity... never installed.
