Oil Circulation Diagram/Engine Sludge Clean Up
07-05-2020, 05:44 AM | #1 |
Rep 3
Ok so I bought a 2008 328i with N52k engine. While changing the OFH gasket I decided to change the valve cover gasket, it was only leaking a tiny bit but figured it wouldn't hurt. Got the plastic cover off and found engine sludge from hell!! It looks terrible, but the stuff isn't baked on there, it pretty much slides on off....sooo I'm going to CAREFULLY clean what I can, while the cover is off and then do a Seafoam or something similar after reassembly.I'm going to make some kind of dam/cover to keep any from going anywhere but out of the engine. I'm trying to find a diagram of the oil circulation path to identify where the ports are or any other areas of importance to be sure they aren't clogged. If I go slow and clean and vacuum thoroughly I'm confident I can get a good portion of the thicker stuff off then let the seafoam do it's thing, just want to make sure ports are clear so the oil will circulate.
I already know how bad the pics look, I already know the cause of the sludge, already have new valve cover and CCV hoses. Just doing a preliminary de-sludging |
07-05-2020, 07:51 AM | #2 |
General
17312
Rep 18,737
Do you have any maintenance history of the car?
07-06-2020, 03:05 AM | #3 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
I do. There hasn't been any maintenance!
For oil flow, see page 52 in this document: BMW N52 Engine Technical Doc.pdf
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
