Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > USA - California > Drilling DPE's for TPMS?
      09-24-2008, 10:20 PM   #1
dArNeLLi
dArNeLLi's Avatar
76
Drives: 335i on ED, pickup 10/6
Anyone in Nor-Cal area done this? Manu sent me some directions on how to do so for the TPMS sensors, though as simple as it is, I'm trying to find someone to do it up in the Nor-cal area that is familiar or has done it before?
      09-25-2008, 12:27 PM   #2
dArNeLLi
dArNeLLi's Avatar
76
Directions from Manu, at DPE
1. The hole will be 180 degrees from the current valve stem hole.
2. Drill half way between the beginning and the end of the radius on the
drop center part of the inner [shown in the drawing]
3. AJ then uses a ¼" spot drill to make a small hole so the 7/16" drill
does not walk all over the inner. [You can also use a punch or something
else if you want]
4. Then drill with the 7/16" drill bit over the hole you spot drilled (or
punched).
      09-25-2008, 03:22 PM   #3
dArNeLLi
dArNeLLi's Avatar
76
http://029d716.netsolstores.com/tpmsstrapkit.aspx
found an option, for anyone in the future who doesn't want to drill
      09-25-2008, 03:24 PM   #4
Ray
Member
Ray's Avatar
306
Drives: three series
      09-25-2008, 03:28 PM   #5
shragon
Moderator
shragon's Avatar
No_Country
497
Drives: BMW
i'd just use that strap kit
      09-25-2008, 11:32 PM   #6
Kensta335
Kensta335's Avatar
161
Drives: 335i Coupe
why drill? Can't you just buy the slimmer valve stems?
      09-26-2008, 12:46 AM   #7
shane335i
shane335i's Avatar
Drives: 2016 BMW M4
I just did this today and all I did was have them transfer the sensor from the OEM wheels to the new wheels.
      09-26-2008, 01:02 AM   #8
dArNeLLi
dArNeLLi's Avatar
76
its not a slim valve stem, its the base of the tpms that needs to sit in the wheel i assume
either way, tpms works for most wheels, most other wheels that have the deep dish (hre/dpe/iforged, etc) need some sort of strap or extra hole depending on where the valve stem is located
      09-26-2008, 01:18 AM   #9
longtran
longtran's Avatar
1434
Drives: E90 M3
2006 325i  [0.00]
i would just get the 90 degree valve stems that holds the tpms inside. the straps can get loose. they look like this
or
      09-26-2008, 08:36 AM   #10
dArNeLLi
dArNeLLi's Avatar
76
ah yea i saw the example of that, but i just ended up buyin the straps, didnt know where to buy those from, thanks for the info
      09-26-2008, 11:12 AM   #11
shragon
Moderator
shragon's Avatar
No_Country
497
Drives: BMW
what long said
      09-26-2008, 11:19 AM   #12
dArNeLLi
dArNeLLi's Avatar
76
yea...
