06-28-2020, 10:31 AM | #1 |
Rep 8
I've coded active hybrid in plugin F30
I know it may sounds greedy, but how would you monetise this code?
Still working on it as when living from stationary need to be extremely gentle with the foot, but much better mpg. on the bmw connected gives around 335mpg when all full (almost, done 5 miles yesterday after full tank and coded today) Also found how to activate efficient dynamics for diesel cars who may don't have it.. |
06-28-2020, 11:46 AM | #2 |
23
Rep 27
I don't understand what you are saying, you have a 330e and have coded it to think it is an activehybrid3?
as a result you are seeing better mpg than standard? 335mpg would be about 3000 miles per tank unless you mean 335miles of range, but that is affected by how you drive the car and is no higher than I would expect to see with a full tank and charged battery. probably just reset the stored values when you coded. |
06-28-2020, 12:24 PM | #3 | |
Rep 8
I have the active hybrid logo on the dash, the car now kills almost the all of the battery juice and charges much quicker. Before wouldn't go below 7/6% and try to charge it.. |
06-28-2020, 12:29 PM | #4 |
23
Rep 27
I think the added range is as a result of the coding resetting the ecu figures then.
if the engine has started during the trip the car will allow the battery to go lower before restarting as it uses some battery starting from cold to maintain the functions. I use max battery mode first and use all of my battery as hybrid mode seems to use the engine sooner and the battery level also drops when it is running. see what your figures show in a few weeks as this will be a better reflection of what the car assumes you can get based on your driving style. |
06-28-2020, 12:48 PM | #5 | |
Rep 8
Now, I've only used for a 10/15 miles, but the mpg I beli e is higher then 48mpg. Tomorrow I will run on battery until it dryes out(may be one hour) then I'll not touch the edrive control and I'll have better numbers |
