TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Battery Spec
      06-27-2020, 11:25 PM   #1
modernist
31
Drives: BMW 328i E91 LCI
Battery Spec
I just picked up a E91 LCI yesterday. Finally, my search is complete.
I found out that the installed replacement battery is incorrect.
I looked in the BMW manual, but could not find the proper spec for the battery.
I understand that I will need to register the new battery from past threads.
Is it true that each car's battery spec voltage may differ depending on which options? If so how do I find out the correct battery spec?
Much appreciated
      07-02-2020, 06:05 PM   #2
Mark963
29
Drives: 2011 328i
2011 BMW 328  [0.00]
The battery is registered to these cars. It has options for flooded or AGM and several capacities from something like 80Ah to 110Ah, I think. Search for registering your BMW battery and you'll find lots of information. You should get a BMW reader or INPA/ISTA+ on a laptop with an appropriate cable to see what the car thinks is installed. As long as the battery matches what is registered, it's fine.
      07-02-2020, 09:44 PM   #3
modernist
31
Thanks Mark963!
