06-26-2020, 11:24 AM | #1 |
472
Rep 1,659
Drives: 2022 WRX World Rally Blue
Lighting Question
Hi
Has anyone replaced the small parking lamp and or DRL in the halogen setup? I have a 2015 F31 and already have Sylvania H7 Silverstars for the high and low beams. I'm just trying to add a little more visibility to my DRLs. I drove cars that had this setup when I drove cars for a local BMW dealership and kind of liked the idea of the LED DRLs. I know the best thing would be to replace the whole crappy setup with Xenon or LED lamps. I just don't have the knowledge or can find anyone locally who can do that. I've driven cars with both and loved them. I do have access to ESys and Bimmercode if that helps. Thanks in advance for all the help!! |
06-26-2020, 12:24 PM | #2 | |
99
Rep 332
For the 24W PW24W DRL I got PW24W LEDs For the 6W H6W 434 Front parking I got H6W LEDs The coding is straightforward: DRLs for LED bulb left/right set LED -- FEM_BODY--3061--TFL_L/R_IS_LED set aktiv from nicht_aktiv left/right no cold check -- FEM_BODY--3061--TFL_L/R_KALTUEBERWACHUNG set nicht_aktiv from aktiv left/right no hot check -- FEM_BODY--3061--TFL_L/R_WARMUEBERWACHUNG set nicht_aktiv from aktiv left/right brightness -- FEM_BODY--3062--MAPPING_TAGFAHRL_V_L/R_PWM_LEVEL_1 set werte=64(100%) from werte=7A(12.2V) I left the next two items unchanged left/right short circuit check -- FEM_BODY--3061--TFL_L/R_KURZSCHLUSS aktiv left/right overvoltage protection -- FEM_BODY--3061--TFL_L/R_UE_SPG_SCHUTZ dimmed Parking Light for LED bulb this is as for the first 3 DRL items, just change TFL to POL These were a massive improvement on the miserable, almost brown colour of the filament bulbs. |
06-26-2020, 12:24 PM | #3 |
8245
Rep 16,086
I replaced my parking lamps with LED, to match the color of the rest of my all LED lighting. I didn't bother with DRL as I don't use them. If you change any bulb you must use Bimmercode to turn off the warm and cold checks and designate the source as LED, not bulb.
06-26-2020, 04:15 PM | #4 |
472
Rep 1,659
Thanks for the quick replies.
Much appreciated!!
Rick
07-20-2020, 06:52 AM | #5 | ||
472
Rep 1,659
Do you still have halogen bulbs for your low and high beam headlights? I'm wondering if installing the H6W LED bulbs would over power the halogen lights when everything is on? Thanks for the help!! Rick
Rick
07-20-2020, 07:19 AM | #6 |
8245
Rep 16,086
07-20-2020, 07:37 AM | #7 | |
472
Rep 1,659
I'm just trying to improve things as I can. I'm not real sure about installing the H7 bulbs. I guess part of my concern is the beam pattern. Some have commented that the OEM setup messes that up. Also, I want to make sure I don't have to alter or eliminate the protective access covers in order to use them.
Rick
07-20-2020, 07:43 AM | #8 | |
99
Rep 332
The bulbs I used for dipped and main were these: https://www.autobulbsdirect.co.uk/tw...s-H7-pair.html Each bulb gave a close pair of adjacent 'hot spots' but the cut-off was excellent. The increase in brightness was night and day (!). The only really bad issue was the bloody difficult access to the main beam bulbs, under the wheel arch. Whoever designed that was a real c##t. However, once in the bulbs fit without any surgery. |
07-20-2020, 08:41 AM | #9 |
8245
Rep 16,086
My beam pattern is the same, although it wasn't great to begin with. Accessing the high beams and fogs is easy enough, but the lows are next to impossible unless you create an access opening yourself on the top of the lamp housing, which I did. http://f30.bimmerpost.com/forums/sho....php?t=1377259
07-20-2020, 10:52 AM | #10 | |
99
Rep 332
07-21-2020, 01:36 AM | #12 |
99
Rep 332
Yes, it's not like a 55W halogen bulb is going to survive for the life of the car. Perhaps they wanted us to replace the whole light unit - this would have been an easier task. It seems a general problem affecting many brands, with a frequent need to remove the front bumper or other body parts. My current all-LED Golf worries me a bit, as it appears to have no replaceable light elements. Damn good lights though.
07-21-2020, 10:37 AM | #13 |
8245
Rep 16,086
Many factory LED don't have replaceable elements because they're not even bulbs in the traditional sense. They justify that by claiming LEDs have a 50 plus year lifespan. Famous last words.
