ugh... Coolant leak
06-25-2020, 07:54 PM | #1 |
31
Rep 112
Drives: 2011 BMW 335i Sedan
ugh... Coolant leak
Here we go again! Another problem with my car. I need help identifying where the coolant is coming from though. Cracked radiator or coolant hose????
2011 BMW 335i N55 |
06-25-2020, 08:08 PM | #3 |
31
Rep 112
06-25-2020, 08:34 PM | #4 |
31
Rep 112
Does anyone know any aftermarket radiators for the auto 335i? I guess it's a good time for an upgrade.
06-25-2020, 08:42 PM | #5 | |
Is it the shoes!?
3884
Rep 5,112
Right around that junction is where it tends to occur. IMO upgraded radiators aren't worth it unless you track it. You can get a Nissens (Japanese OEM) for under $100, or a Behr (OEM) for around $150. |
theslowe9031.00 |
06-26-2020, 01:20 PM | #6 |
31
Rep 112
UPDATE
Went for a drive and found the leak. Such a small crack. Not sure if I should use a plastic welder or replace the radiator. Suggestions?
06-26-2020, 01:26 PM | #7 | |
1905
Rep 6,968
CSF is $450-500.00 If you are tracking the car, CSF is worth it. If not, don't bother. For $175.00 and a fairly easy DIY, I wouldn't try and patch it up. It's not worth the headache. The only other thing I would do, is replace all your o-rings while you are in there. Especially if you are over say 125,000 miles |
theslowe9031.00 |
06-26-2020, 02:08 PM | #8 | |
Is it the shoes!?
3884
Rep 5,112
06-26-2020, 02:11 PM | #9 |
31
Rep 112
Yea, I think I'm gonna use a plastic welder for a temporary fix. I will replace the radiator when I get an upgraded intercooler since that needs to be removed when replacing the radiator.
