335d EGR thermostat?
06-14-2020, 02:00 PM | #2 |
307
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
NO.
The EGR cooler on the M57 has a temperature sensor and an engine coolant loop. However, the cooler does not have a thermostat to control coolant flow. https://f15.bimmerpost.com/forums/at...mentid=1235091 |
_N54299.50 |
06-14-2020, 02:06 PM | #3 |
300
Rep 884
Interesting. I keep getting fault P2457 Exhaust Gas Recirculation (EGR) Cooling System Performance. My engine thermostat was broken i replaced it and my EGR cooler was seeping coolant from the welds so i also replaced that. I can't think of anything else that would cause the "EGR cooling system performance" fault code.
2013 335is - sold
2011 335d |
06-18-2020, 09:56 PM | #4 |
Who reads these?
234
Rep 107
M57 does have a EGR thermostat. 25d and 30d definitely does, but with 35d it seems like some do, others don't.
Market differences? I have found engine bay pics of 35d cars WITH the thermostat, and 35d cars WITHOUT the thermostat. Here is one with the thermostat (red ring). Ignore the yellow line. When I check RealOEM with the VIN of my car, it shows up with partnumber.
Instagram: daniel.35d
_N54299.50 |
06-19-2020, 12:39 PM | #5 | |
300
Rep 884
2013 335is - sold
2011 335d |
daniel35d234.00 |
06-19-2020, 12:43 PM | #6 | |
Who reads these?
234
Rep 107
Yeah, maybe a proper BMW diagnostic tool can be more helpful. Hope you figure it out
06-19-2020, 12:48 PM | #7 |
300
Rep 884
Big possibility and i think the X5 M57 might have the EGR cooler thermostat. Wish i could just D-E-L-E-T-E everything, but i can't deal with the emissions inspection headache every 2 years in California.
2013 335is - sold
2011 335d |
06-27-2020, 10:55 AM | #9 |
300
Rep 884
Thank you. I'm starting to think i possibly have carbon build up. Most likely going to order a new intake manifold to replace and try to clean out the valves.
2013 335is - sold
2011 335d |
06-27-2020, 04:15 PM | #10 | |
274
Rep 1,054
I can't imagine carbon build up would cause a coolant issue.
2011 335d tuned by B.R.R.
2011 X5 35d tuned by B.R.R. |
06-27-2020, 11:01 PM | #11 | |
300
Rep 884
My thermostat was replaced at the same time as the EGR cooler because the temperatures weren't going up and I found the thermostat spring broken when I removed it. My EGR cooler was leaking coolant from the welds that appeared to crack so I replaced it at the same time. My coolant temperature is around 180-190F if I recall correctly checking with my Carly app.
2013 335is - sold
2011 335d |
06-28-2020, 11:48 AM | #12 | |
274
Rep 1,054
I also wonder if the egr EUV being bad has anything to do with the cooling performance of the egr cooler.
06-28-2020, 01:06 PM | #13 | ||
300
Rep 884
I have a brand new intake manifold on its way. I'm going to carbon clean the valves, replaced EGR valve and the intake manifold and see what direction it leads me after.
2013 335is - sold
2011 335d |
06-28-2020, 02:02 PM | #14 | |
274
Rep 1,054
I think I have a egr valve from my 335d still if your looking for one!
_N54299.50 |
