06-14-2020, 06:32 AM | #1 |
Rep 17
F3x airbag reset ... lost !!!
Afternoon guys,
I bought a crashed '16 F33 at auction. It has some minor panel damage at the front left but the impact was decent enough to blow the dash-airbags, BST and belt pre-tensioners. I have a 2nd hand dash with airbags, belt-tensioners and battery terminal on the way and once that's all installed I understand I need to reset the airbag-module (ASCM?). I have been reading for the last days trying to figure out how to do this and just can't get my head around it! I downloaded ISTA+ and an ENET cable is on its way but don't knowif this is the right combo to get the job done and if so, what the process is. Or do I need ESYS or Tool32 and/or a different cable? I read though a few "First steps" documents but they all end in bottomless threads and I just seem to be digging deeper down the rabbit hole leaving more questions than answers. Any help is greatly appreciated. Thanks! Last edited by Mongobear; 06-14-2020 at 06:40 AM.. |
06-14-2020, 04:57 PM | #2 |
185
Rep 780
As long as you're not replacing the airbag module, you should only need to clear airbag codes. This can be done with esys, tool32, ista, bmw Carly, Bimmerlink etc. This is assuming there is no crash data that needs to be reset within the module.
06-14-2020, 08:12 PM | #3 | |
Rep 17
How would I know if crash data needs to be reset and if so, how would I go about it? Since the airbags have gone off (and the rollover protection bars) I guess it will have crash data stored. |
06-14-2020, 10:42 PM | #4 | ||
185
Rep 780
06-16-2020, 09:29 PM | #6 | ||
153
Rep 438
Drives: F30 335i M Sport
Clear codes after all replacement equipment is installed and you should be fine. |
06-16-2020, 09:47 PM | #7 | |||
185
Rep 780
06-17-2020, 07:08 AM | #8 | ||||
153
Rep 438
06-17-2020, 02:09 PM | #9 | |||||
185
Rep 780
07-13-2020, 04:47 PM | #10 |
Rep 17
Still waiting for the new seat-buckle tensioners to arrive but have replaced the belt-internal tensioners and dash-airbags already and can't see them popping up as errors any longer after clearing the fault-memory. Will update once all SRS gear is installed.
07-19-2020, 05:35 PM | #11 |
Rep 17
Just bringing this to a close. I finally received the buckle tensioners and installed them on the weekend.
Went into ISTA+ and cleared the fault-memory and airbag light is off now. Cheers |
