06-13-2020, 04:47 PM | #1 |
45
Rep 176
Comfort Access Timing
Hi guys, any of you know if there's a way to adjust the timing on comfort access through coding so that when I close the door, it immediately enables itself so I can lock the door right away? I typically try to lock the doors and I feel like an idiot waiting for it to respond.
Not sure if it's normal or if there's something wrong with it. It's also very annoying that when say for example I drop someone off, as soon as they close the door, it says the engine won't run cause the key is not present. I find it very annoying of course. Let me know what you think! |
06-14-2020, 09:25 AM | #2 | |
336
Rep 365
Sounds to me that the key is the common denominator here since that is not a normal occurrence. |
