BMW X3 Forum
BMW X3 Forum
Welcome to the ultimate BMW X3 community.
      06-13-2020, 05:31 AM   #1
Gcam37
Drives: 2006 X3
Expected life span 2006 X3??
Looking at making my first BMW purchase.
It is a high mileage (180,000 miles) 2006 X3, 3.0 that the previous owner has done a lot of current work to.
The vehicle looks like it is quite rust-free, and has a mechanical inspection report available from 2 different garages.
I don't know anything about these vehicles. Can you get 200,000 miles out of them? 250,000 miles out of them?
Thanks for any information.
List of recent work from the ad:
"front and rear driveshafts replaced new, left rear wheel bearing replaced, and rear control links and rear brake pads. Last month a new battery. This week left rear calliper and rear ABS Sensors. Last summer 2 new rear springs, rear oxygens sensors and left and right front CV Axles Sensors. Last winter front struts and springs and front wheel bearings (Left and Right). New vented rotors in October and pads front and back. Needs backing plates for rear emergency brakes, I have the shoes and hardware to go with it. Plugs done last winter. "
      08-16-2020, 02:23 PM   #2
englishtom1596
Drives: 07 BMW X3/ 98 BMW M3
the N52 is a super reliable engine mechanically. Its all the bits around it that fail. with that said you can easily expect 200-250K out of a well maintained one. Big question is transfer case. as its a big ticket item when it goes. and they do go regularly
      08-17-2020, 06:57 PM   #3
stein_325i
Ring Leader of G8X Haters
stein_325i's Avatar
No_Country
25083
Drives: A Car
You can, just be ready to pay the price...
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300
      01-01-2021, 05:20 AM   #4
bimmerman14
bmw doctor
bimmerman14's Avatar
10
Drives: x7(kid hauler) 13 x550i 07328i
M54 engine is great very reliable
      01-01-2021, 10:12 PM   #5
Bmw1939
268
Drives: BMW 2011 328i, 2008 BMW X3
I lucked out with the one I just bought. The transfer case gear was just replaced. I hope it holds up.
      02-12-2021, 09:40 AM   #6
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
My transfer case went out at about 100k miles. Cost $5k but I had bought one of those aftermarket warranties. Thank goodness! Every seal has been replaced too. Oil pan, oil filter housing, valve cover. Just waiting for the cooling system to blow. Overall this has not been the most reliable BMW I've had. In the almost 4 years I've owned it, from 65k miles to currently 110k miles, I've put over $10k into it. (That's including the amount paid by the warranty).
      07-09-2021, 07:13 PM   #7
XDRESSER
15
Drives: 2018 BMW X3 M40i
I begrudgingly sold my 2006 MT X3 recently that I had custom ordered. It was the most trouble free car I have owned and I was very attached to it! 170,000 miles, only coolant expansion tank and rear driveline replaced in that time - and upgraded to Bilstein HD shocks by choice. Oh, and a rear window regulator. The clutch was still original and felt solid. Otherwise just oil changes and brakes. Not bad for 15 years.
      10-30-2021, 06:41 AM   #8
vibexxx
Drives: 2012 BMW M5
expected life span 2006 X3
M54 engine is great very reliable truly
      01-23-2022, 11:30 AM   #9
Cali_MSport
Cali_MSport's Avatar
30
Drives: 2013 F30, 06 325i, 07 328i
I own a 2006 that's been a great vehicle I currently have 173k on the odometer. Right now I'm driving it as a RWD vehicle because I need to replace the gear in the actuator motor. So far I've replaced rear window regulators, the blower motor, the expansion tank, thermostat, and oil filter housing gasket. Not counting brakes wiper blades and basic maintenance items like oil and plugs. I have the M54. I'd say you could get 300k and than some out of these if you kept it up well. I am currently having some cooling system issues and leaks etc. expect the o rings in the hoses to go bad you can buy a kit on eBay for $20
