BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Crank Hub Issue - which engines affected?
      06-11-2020, 03:46 AM   #1
Phil325i
Phil325i's Avatar
616
Drives: E92 325i MSport Coupe
As per the title really.
Been reading about the issue with the S55 crank hub. In brief, BMW threw out the last 100 years of engine development and decided to lock the crank gear to the crankshaft with nothing more than a diamond sintered washer, and a load of torque from the crank bolt to hold the timing in place. In certain circumstances the bolt moves and no longer holds the timing accurately. As the S55 is an interference engine, the results can be catastrophic.
My question is: does anyone know if this design feature is found on other BMW engines? Looking at RealOEM it appears this may well be the case on other engine series, but I wanted to know for sure.
Cheers...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      06-11-2020, 10:20 AM   #2
Efthreeoh
General
17314
Drives: The E90 + Z4 Coupe & Z3 R'ster
N52 is the same.
      06-29-2020, 05:27 PM   #3
Dormermike
102
Drives: Bmw f10
N53 also iirc
Phil325i615.50
      06-30-2020, 10:26 AM   #4
CTinline-six
Hoonigan
CTinline-six's Avatar
6848
Drives: '09 328i, '98 Wrangler
It seems to only be an issue for engines with higher HP, especially tuned engines.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park
      06-30-2020, 11:19 AM   #5
Phil325i
Phil325i's Avatar
616
Yeah I think you're right. And as well as aftermarket 'solutions' I also picked up that BMW have modified the sprockets by introducing a band of laser etching around the circumference, presumably to increase the friction between the face of the sprocket and the crankshaft.
      07-21-2020, 04:14 AM   #6
Js235
Drives: BMW 335i N54 - ex-BMW 130i
I think N54 have same system
