06-08-2020, 11:13 AM | #1 |
Rep 11
Help Water In Back Passanger
I am experiencing water in the rear back passenger seat during heavy rain. i cleaned out the rain channels on the roof and in the truck area. i cant really tell where its coming from.
06-08-2020, 03:40 PM | #2 |
417
Rep 919
Maybe through your antenna and the upper brake light panel? If you mean 'on the seat.'
Another possibility might be from the rear sunroof drain down the c-pillar somehow. If you need to tear apart anything newtis.info is too helpful! BTW, had you had any work done on the roof...like a wrap or something where they'd removed the sharkfin?
06-08-2020, 08:01 PM | #3 |
127
Rep 339
Check seal around sunroof, those were known to go bad before...probably due to dry rot, if your car is kept outside a lot. Salt degrades the seal too...
06-15-2020, 05:55 AM | #4 |
Rep 11
Im getting water on the floor of the rear passenger seat. There's no sign of water coming from other places. Its a large amount of water. its not wet on the sides or headliner, nothing anywhere else it just some how pools up in the rear passenger.
06-15-2020, 06:14 AM | #5 | |
45
Rep 144
I hope it helps and you get this fixed asap, as if left unchecked, this issue could lead to rust / corrosion. Please provide further details, such as where on the rear floor area, you've noticed water damage (if it's close to the sides, it could be damaged weatherstripping, if closer to the middle area, I'd have the A/C drain checked. Last edited by zatelli; 06-15-2020 at 06:18 AM.. Reason: Further details added |
06-15-2020, 07:32 PM | #6 |
PsyD
102
Rep 156
Drives: 2016 340i M-sport
Replaced the vapor barrier in my passenger doors, front and rear a few weeks ago due to a similar problem. Check the sunroof drain and the vapor barriers.
