F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 LCI LED headlight coding
proTUNING Freaks
      06-04-2020, 01:15 PM   #1
dkaltanas@yahoo.co.uk
Dovydas112
England
Drives: F30 330d
I have replaced my headlight on my car (2016 330 LED) and from what I was aware I needed to code in the new headlight, from my research most people said to simply using ista+ go through the service functions and find the headlight option but for some reason I cant seem to find it. Is anyone able to help or at least guide me in the right direction?
Under vehicle management - service functions - body— i can find only lighting which then offers ride height adjustment and teach in front light electronic turn signal... both I have tried and no difference.
Headlight itself if i connected once the car is running it functions fine until the car is turned off and turned back on and then it doesnt turn on at all.
Thanks
      06-04-2020, 01:37 PM   #2
atzebmw
Germany
588
Drives: Tesla Model 3
Please describe in more detail what you did.
Didn't the car have LED headlight before and you upgraded it now?
Or did you just change any lamps to LED?
If you changed the headlights it has to be coded.
For that i would recommend E-Sys.
      06-04-2020, 02:50 PM   #3
Billfitz
Billfitz's Avatar
8245
Drives: '15 328iX GT
You should reconsider having your email address as a username. Bots cruise the web looking for email addresses to bombard with spam.
      06-07-2020, 03:51 PM   #4
Dovydas112
England
Drives: F30 330d
The car was involved in an accident and so I replaced one of the LED headlights so i presume it need to be coded in as it isn’t functioning correctly as I mentioned above.
      06-07-2020, 03:53 PM   #5
Dovydas112
England
Drives: F30 330d
Just realised, thanks will change it!
      06-07-2020, 03:55 PM   #6
Dovydas112
England
Drives: F30 330d
Also is there any guide on how to do it anywhere on E-sys? I will need to get E-sys first as I don't recall installing it
      06-07-2020, 10:18 PM   #7
helix247
17
Drives: BMW 2013 328i
Try with a search for LED headlight retrofits. If there is coding, it would have been done and the relevant bits may stand out.
      06-11-2020, 11:55 AM   #8
Dovydas112
England
Drives: F30 330d
Tried to search but cant seem to find anyone who specifically has gone through how to code a headlight for that model :?
      06-11-2020, 12:01 PM   #9
atzebmw
Germany
588
Do you already have E-Sys?
      06-11-2020, 06:11 PM   #10
helix247
17
2nd on this one. You will need it I believe to code the headlights anyway. If there are threads that show the requirements for later year 328i or 335i, there may not be much if any difference in the entries that have to modified for this specific requirement on a 330.
      06-12-2020, 03:12 PM   #11
Dovydas112
England
Drives: F30 330d
Yes I do have E-Sys
      06-13-2020, 07:58 AM   #12
atzebmw
Germany
588
Yes I do have E-Sys
OK.
And did you already connect E-Sys with your car or read out the ecus?
      09-15-2023, 01:08 PM   #13
PedroRios
Drives: Bmw 320i f30
Does anyone know how to disable the angel eyes completely? Even when you have a position light or headlight on? Via bimmercood
      09-15-2023, 01:14 PM   #14
PedroRios
How to remove the light error of the angel eyes burned from the panel? I removed the lights and would like to stay without them and without the error in the panel, via bimmercode...
Tags
bmw, coding, f30, headlight, led
f30post
