05-30-2020, 10:42 PM | #1 |
472
Rep 1,659
Drives: 2022 WRX World Rally Blue
LED Voltage
I replaced all my rear lights with LED bulbs.
I've done all the warm and cold check coding. Do I also need to increase the voltage to 13.7 also?? Thanks for the help in advance!!
Rick
05-31-2020, 07:19 AM | #2 |
8245
Rep 16,086
I'm not aware of a voltage adjustment. You should change the lamp settings from bulb to LED. This doesn't change the drive voltage level, it changes the voltage from pulsed wave to pure DC.
05-31-2020, 10:05 AM | #3 | |
472
Rep 1,659
I am going to be converting my F87 to full LED and I know that you have to change the voltage settings. I already have converted my 15 F31 by just changing the bulbs to LED. I coded out the cold and warm checks and set all the lights to LED. I was just wondering about there being a necessity to change the voltage on my F31 since they were now LED to get the maximum brightness out of them. |
05-31-2020, 07:51 PM | #5 | ||
Luxury at the redline :)
9105
Rep 7,563
All the BMW LEDs are already independently power regulated, regardless of the the amperage it receives. So, as suggest, just code the settings from "bulb" to "LED" and it will be fine. |
05-31-2020, 10:10 PM | #6 |
8245
Rep 16,086
AFAIK the bulb versus LED settings don't affect voltage, though I've not bothered to measure it. The bulb setting uses pulse wave modulation to rapidly turn the power to the bulb on and off. You can't see it, because bulbs don't react fast enough. This reduces the current load, which allows everything from a smaller alternator to lighter gauge wires, all in the interest of saving weight and reducing the load on the engine. LEDs react almost instantly to power modulation, so you might see flicker with the bulb setting. The LED setting provides constant voltage, so there can't be any flicker. Current load isn't a problem, as LEDs only draw about 1/10 the current that incandescent bulbs do.
