05-28-2020, 12:07 AM | #1 |
172
Rep 740
Flashing ECU(KAFAS2) error - WDBI_CPS returned a negative response
I'm retrofitting the KAFAS2 with KAFAS2 emulator/activator and Shawn told me the ECU lost its vin and to modify the FA with donor vin and flash (Thanks Shawn for your help!). I followed the "upgrading ecu" guide. Tried both gateway url and connection via vin. These were the steps I did.
-Read and save FA, modify FA to change "longvin" to the donor vin and save. -activate FA, read svt, select complete flash and for the istep shipment, I had to pick one based on the donor cars and found one that makes HWEL black. calculate and save as SVT_SOLL.xml -do TAL calculation and save as SVT_TAL.xml -in tal-processing, i load SVT_tal, svt target and the FA with the fake vin. it does pull the donor vin in the vin field. -uncheck all, and only kafas2 - > blFlash, swDeploy, and cdDeploy. towards the end, it fails with the error message below... I even tried changing the FA to match what the donor car had thats dependent to KAFAS2 (5AC, 5AP, 5AS) trimmed error log...(full log at the bottom) [KAFAS2 - 5D - cafd_00001148-000_033_001] Transaction type: cdDeploy; Message: TA started [TRANSACTION] [KAFAS2 - 5D - cafd_00001148-000_033_001] Transaction type: cdDeploy; Message: TA finished [TRANSACTION] [KAFAS2 - 5D] finalizeECUCoding started [PROGRESS] MCDDiagService<id=80649, job=com.bmw.psdz.jobs.uds.MCD3_FinalizeECUCoding, service=WDBI_CPS - WriteDataByIdentifier Codierpruefstempel, description=error: negative response : requestOutOfRange, link=KAFAS2_5D_ETHERNET> [DIAGSERVICE] [KAFAS2 - 5D] finalizeECUCoding error [PROGRESS] [] job failed with negative response error: code: service returned global negative response description: Service WDBI_CPS returned a negative response with response code requestOutOfRange; LinkName: KAFAS2_5D_ETHERNET severity: ERROR [THROWABLE] [KAFAS2 - 5D] There was an error during TAL execution, please check the log files. [WARN] [KAFAS2 - 5D] - [Exception - KAFAS2 - 5d] job failed with negative response error: code: service returned global negative response description: Service WDBI_CPS returned a negative response with response code requestOutOfRange; LinkName: KAFAS2_5D_ETHERNET severity: ERROR [] finalizeVehicleCoding started [PROGRESS] [] finalizeVehicleCoding finished [PROGRESS] [] finalizeTALExecution started [PROGRESS] [] finalizeTALExecution finished [PROGRESS] TAL execution finished [TAL_EXECUTION_FINISHED] TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "17min 27s". [C206] Read SVT after TAL execution started. Read SVT after TAL execution finished. Code:
Read SVT before TAL execution started. TAL execution started. VCM Update: VCM-Update is deactivated. VCM will not be updated. [C197] ExecutionID=2020/05/27-23:56:02.307 [] prepareTALExecution started [PROGRESS] [] prepareTALExecution finished [PROGRESS] [] prepareVehicleForFlash started [PROGRESS] [] prepareVehicleForFlash finished [PROGRESS] [KAFAS2 - 5D] prepareECUforBLUpdate started [PROGRESS] [KAFAS2 - 5D] prepareECUforBLUpdate finished [PROGRESS] [KAFAS2 - 5D] authenticateECUforBLUpdate started [PROGRESS] [KAFAS2 - 5D] authenticateECUforBLUpdate finished [PROGRESS] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: TA started [TRANSACTION] [KAFAS2 - 5D] performECUBLUpdate started with protocol UDS [PROGRESS] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [0% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [3% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [10% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [18% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 0% progress on ECUId:KAFAS2_0x5D [25% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 1% progress on ECUId:KAFAS2_0x5D [32% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 1% progress on ECUId:KAFAS2_0x5D [40% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 1% progress on ECUId:KAFAS2_0x5D [47% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 1% progress on ECUId:KAFAS2_0x5D [55% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 2% progress on ECUId:KAFAS2_0x5D [63% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 2% progress on ECUId:KAFAS2_0x5D [70% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 2% progress on ECUId:KAFAS2_0x5D [78% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 2% progress on ECUId:KAFAS2_0x5D [86% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 2% progress on ECUId:KAFAS2_0x5D [94% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 3% progress on ECUId:KAFAS2_0x5D [100% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 3% progress on ECUId:KAFAS2_0x5D [100% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: 3% progress on ECUId:KAFAS2_0x5D [100% of flsl_00001421-000_022_001] [TRANSACTION] [KAFAS2 - 5D - flsl_00001421-000_022_001] Transaction type: blFlash; Message: TA finished [TRANSACTION] [KAFAS2 - 5D - btld_00001420-000_033_001] Transaction type: blFlash; Message: TA started [TRANSACTION] [KAFAS2 - 5D] performECUBLUpdate started with protocol UDS [PROGRESS] [KAFAS2 - 5D - btld_00001420-000_033_001] Transaction type: blFlash; Message: 3% progress on ECUId:KAFAS2_0x5D [0% of btld_00001420-000_033_001] [TRANSACTION] [KAFAS2 - 5D - btld_00001420-000_033_001] Transaction type: blFlash; Message: 3% progress on ECUId:KAFAS2_0x5D [15% of btld_00001420-000_033_001] [TRANSACTION] [KAFAS2 - 5D - btld_00001420-000_033_001] Transaction type: blFlash; Message: 3% progress on ECUId:KAFAS2_0x5D [82% of btld_00001420-000_033_001] [TRANSACTION] [KAFAS2 - 5D - btld_00001420-000_033_001] Transaction type: blFlash; Message: 3% progress on ECUId:KAFAS2_0x5D [100% of btld_00001420-000_033_001] [TRANSACTION] [KAFAS2 - 5D - btld_00001420-000_033_001] Transaction type: blFlash; Message: 3% progress on ECUId:KAFAS2_0x5D [100% of btld_00001420-000_033_001] [TRANSACTION] [KAFAS2 - 5D - btld_00001420-000_033_001] Transaction type: blFlash; Message: TA finished [TRANSACTION] [KAFAS2 - 5D] installECUBL started [PROGRESS] [KAFAS2 - 5D] installECUBL finished [PROGRESS] [KAFAS2 - 5D] finalizeECUBLUpdate started [PROGRESS] [KAFAS2 - 5D] finalizeECUBLUpdate finished [PROGRESS] [KAFAS2 - 5D] prepareECUforFlash started [PROGRESS] [KAFAS2 - 5D] prepareECUforFlash finished [PROGRESS] [KAFAS2 - 5D] authenticateECUforFlash started [PROGRESS] [KAFAS2 - 5D] authenticateECUforFlash finished [PROGRESS] [KAFAS2 - 5D - swfl_000011eb-000_032_002] Transaction type: swDeploy; Message: TA started [TRANSACTION] [KAFAS2 - 5D] performEcuFlash started with protocol UDS [PROGRESS] [KAFAS2 - 5D - swfl_000011eb-000_032_002] Transaction type: swDeploy; Message: 3% progress on ECUId:KAFAS2_0x5D [100% of swfl_000011eb-000_032_002] [TRANSACTION] [KAFAS2 - 5D - swfl_000011eb-000_032_002] Transaction type: swDeploy; Message: TA finished [TRANSACTION] [KAFAS2 - 5D - swfl_00001422-000_033_001] Transaction type: swDeploy; Message: TA started [TRANSACTION] [KAFAS2 - 5D] performEcuFlash started with protocol UDS [PROGRESS] [KAFAS2 - 5D - swfl_00001422-000_033_001] Transaction type: swDeploy; Message: 3% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001422-000_033_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001422-000_033_001] Transaction type: swDeploy; Message: 3% progress on ECUId:KAFAS2_0x5D [5% of swfl_00001422-000_033_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001422-000_033_001] Transaction type: swDeploy; Message: 3% progress on ECUId:KAFAS2_0x5D [20% of swfl_00001422-000_033_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001422-000_033_001] Transaction type: swDeploy; Message: 3% progress on ECUId:KAFAS2_0x5D [34% of swfl_00001422-000_033_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001422-000_033_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [51% of swfl_00001422-000_033_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001422-000_033_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [66% of swfl_00001422-000_033_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001422-000_033_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [82% of swfl_00001422-000_033_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001422-000_033_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [93% of swfl_00001422-000_033_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001422-000_033_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [100% of swfl_00001422-000_033_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001422-000_033_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [100% of swfl_00001422-000_033_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001422-000_033_001] Transaction type: swDeploy; Message: TA finished [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: TA started [TRANSACTION] [KAFAS2 - 5D] performEcuFlash started with protocol UDS [PROGRESS] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 4% progress on ECUId:KAFAS2_0x5D [0% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 5% progress on ECUId:KAFAS2_0x5D [1% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 5% progress on ECUId:KAFAS2_0x5D [1% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 5% progress on ECUId:KAFAS2_0x5D [1% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 6% progress on ECUId:KAFAS2_0x5D [2% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 6% progress on ECUId:KAFAS2_0x5D [2% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 6% progress on ECUId:KAFAS2_0x5D [2% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 6% progress on ECUId:KAFAS2_0x5D [2% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 7% progress on ECUId:KAFAS2_0x5D [3% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 7% progress on ECUId:KAFAS2_0x5D [3% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 7% progress on ECUId:KAFAS2_0x5D [3% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 7% progress on ECUId:KAFAS2_0x5D [3% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 8% progress on ECUId:KAFAS2_0x5D [4% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 8% progress on ECUId:KAFAS2_0x5D [4% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 8% progress on ECUId:KAFAS2_0x5D [4% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 8% progress on ECUId:KAFAS2_0x5D [4% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 9% progress on ECUId:KAFAS2_0x5D [5% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 9% progress on ECUId:KAFAS2_0x5D [5% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 9% progress on ECUId:KAFAS2_0x5D [5% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 9% progress on ECUId:KAFAS2_0x5D [5% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 10% progress on ECUId:KAFAS2_0x5D [6% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 10% progress on ECUId:KAFAS2_0x5D [6% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 10% progress on ECUId:KAFAS2_0x5D [6% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 10% progress on ECUId:KAFAS2_0x5D [6% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 11% progress on ECUId:KAFAS2_0x5D [7% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 11% progress on ECUId:KAFAS2_0x5D [7% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 11% progress on ECUId:KAFAS2_0x5D [7% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 11% progress on ECUId:KAFAS2_0x5D [7% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 12% progress on ECUId:KAFAS2_0x5D [8% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 12% progress on ECUId:KAFAS2_0x5D [8% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 12% progress on ECUId:KAFAS2_0x5D [8% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 12% progress on ECUId:KAFAS2_0x5D [8% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 13% progress on ECUId:KAFAS2_0x5D [9% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 13% progress on ECUId:KAFAS2_0x5D [9% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 13% progress on ECUId:KAFAS2_0x5D [9% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 13% progress on ECUId:KAFAS2_0x5D [9% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 14% progress on ECUId:KAFAS2_0x5D [10% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 14% progress on ECUId:KAFAS2_0x5D [10% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 14% progress on ECUId:KAFAS2_0x5D [10% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 14% progress on ECUId:KAFAS2_0x5D [10% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 15% progress on ECUId:KAFAS2_0x5D [11% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 15% progress on ECUId:KAFAS2_0x5D [11% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 15% progress on ECUId:KAFAS2_0x5D [11% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 15% progress on ECUId:KAFAS2_0x5D [11% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 16% progress on ECUId:KAFAS2_0x5D [12% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 16% progress on ECUId:KAFAS2_0x5D [12% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 16% progress on ECUId:KAFAS2_0x5D [12% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 16% progress on ECUId:KAFAS2_0x5D [12% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 17% progress on ECUId:KAFAS2_0x5D [13% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 17% progress on ECUId:KAFAS2_0x5D [13% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 17% progress on ECUId:KAFAS2_0x5D [13% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 17% progress on ECUId:KAFAS2_0x5D [13% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 18% progress on ECUId:KAFAS2_0x5D [14% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 18% progress on ECUId:KAFAS2_0x5D [14% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 18% progress on ECUId:KAFAS2_0x5D [14% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 18% progress on ECUId:KAFAS2_0x5D [14% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 19% progress on ECUId:KAFAS2_0x5D [15% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 19% progress on ECUId:KAFAS2_0x5D [15% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 19% progress on ECUId:KAFAS2_0x5D [15% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 19% progress on ECUId:KAFAS2_0x5D [15% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 20% progress on ECUId:KAFAS2_0x5D [16% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 20% progress on ECUId:KAFAS2_0x5D [16% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 20% progress on ECUId:KAFAS2_0x5D [16% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 20% progress on ECUId:KAFAS2_0x5D [16% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 21% progress on ECUId:KAFAS2_0x5D [17% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 21% progress on ECUId:KAFAS2_0x5D [17% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 21% progress on ECUId:KAFAS2_0x5D [17% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 21% progress on ECUId:KAFAS2_0x5D [17% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 21% progress on ECUId:KAFAS2_0x5D [18% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 21% progress on ECUId:KAFAS2_0x5D [18% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 21% progress on ECUId:KAFAS2_0x5D [18% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 21% progress on ECUId:KAFAS2_0x5D [18% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 22% progress on ECUId:KAFAS2_0x5D [19% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 22% progress on ECUId:KAFAS2_0x5D [19% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 22% progress on ECUId:KAFAS2_0x5D [19% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 22% progress on ECUId:KAFAS2_0x5D [19% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 23% progress on ECUId:KAFAS2_0x5D [20% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 23% progress on ECUId:KAFAS2_0x5D [20% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 23% progress on ECUId:KAFAS2_0x5D [20% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 23% progress on ECUId:KAFAS2_0x5D [20% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 24% progress on ECUId:KAFAS2_0x5D [21% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 24% progress on ECUId:KAFAS2_0x5D [21% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 24% progress on ECUId:KAFAS2_0x5D [21% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 24% progress on ECUId:KAFAS2_0x5D [21% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 25% progress on ECUId:KAFAS2_0x5D [22% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 25% progress on ECUId:KAFAS2_0x5D [22% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 25% progress on ECUId:KAFAS2_0x5D [22% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 25% progress on ECUId:KAFAS2_0x5D [22% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 26% progress on ECUId:KAFAS2_0x5D [23% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 26% progress on ECUId:KAFAS2_0x5D [23% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 26% progress on ECUId:KAFAS2_0x5D [23% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 26% progress on ECUId:KAFAS2_0x5D [23% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 27% progress on ECUId:KAFAS2_0x5D [24% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 27% progress on ECUId:KAFAS2_0x5D [24% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 27% progress on ECUId:KAFAS2_0x5D [24% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 27% progress on ECUId:KAFAS2_0x5D [24% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 28% progress on ECUId:KAFAS2_0x5D [25% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 28% progress on ECUId:KAFAS2_0x5D [25% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 28% progress on ECUId:KAFAS2_0x5D [25% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 28% progress on ECUId:KAFAS2_0x5D [25% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 29% progress on ECUId:KAFAS2_0x5D [26% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 29% progress on ECUId:KAFAS2_0x5D [26% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 29% progress on ECUId:KAFAS2_0x5D [26% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 29% progress on ECUId:KAFAS2_0x5D [26% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 30% progress on ECUId:KAFAS2_0x5D [27% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 30% progress on ECUId:KAFAS2_0x5D [27% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 30% progress on ECUId:KAFAS2_0x5D [27% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 30% progress on ECUId:KAFAS2_0x5D [27% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 31% progress on ECUId:KAFAS2_0x5D [28% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 31% progress on ECUId:KAFAS2_0x5D [28% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 31% progress on ECUId:KAFAS2_0x5D [28% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 31% progress on ECUId:KAFAS2_0x5D [28% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 32% progress on ECUId:KAFAS2_0x5D [29% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 32% progress on ECUId:KAFAS2_0x5D [29% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 32% progress on ECUId:KAFAS2_0x5D [29% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 32% progress on ECUId:KAFAS2_0x5D [29% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 33% progress on ECUId:KAFAS2_0x5D [30% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 33% progress on ECUId:KAFAS2_0x5D [30% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 33% progress on ECUId:KAFAS2_0x5D [30% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 33% progress on ECUId:KAFAS2_0x5D [30% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 34% progress on ECUId:KAFAS2_0x5D [31% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 34% progress on ECUId:KAFAS2_0x5D [31% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 34% progress on ECUId:KAFAS2_0x5D [31% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 34% progress on ECUId:KAFAS2_0x5D [31% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 35% progress on ECUId:KAFAS2_0x5D [32% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 35% progress on ECUId:KAFAS2_0x5D [32% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 35% progress on ECUId:KAFAS2_0x5D [32% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 35% progress on ECUId:KAFAS2_0x5D [32% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 36% progress on ECUId:KAFAS2_0x5D [33% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 36% progress on ECUId:KAFAS2_0x5D [33% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 36% progress on ECUId:KAFAS2_0x5D [33% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 36% progress on ECUId:KAFAS2_0x5D [33% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 37% progress on ECUId:KAFAS2_0x5D [34% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 37% progress on ECUId:KAFAS2_0x5D [34% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 37% progress on ECUId:KAFAS2_0x5D [34% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 38% progress on ECUId:KAFAS2_0x5D [35% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 38% progress on ECUId:KAFAS2_0x5D [35% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 38% progress on ECUId:KAFAS2_0x5D [35% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 38% progress on ECUId:KAFAS2_0x5D [35% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 39% progress on ECUId:KAFAS2_0x5D [36% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 39% progress on ECUId:KAFAS2_0x5D [36% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 39% progress on ECUId:KAFAS2_0x5D [36% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 39% progress on ECUId:KAFAS2_0x5D [36% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 40% progress on ECUId:KAFAS2_0x5D [37% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 40% progress on ECUId:KAFAS2_0x5D [37% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 40% progress on ECUId:KAFAS2_0x5D [37% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 40% progress on ECUId:KAFAS2_0x5D [37% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 40% progress on ECUId:KAFAS2_0x5D [38% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 40% progress on ECUId:KAFAS2_0x5D [38% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 40% progress on ECUId:KAFAS2_0x5D [38% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 40% progress on ECUId:KAFAS2_0x5D [38% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 41% progress on ECUId:KAFAS2_0x5D [39% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 41% progress on ECUId:KAFAS2_0x5D [39% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 41% progress on ECUId:KAFAS2_0x5D [39% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 41% progress on ECUId:KAFAS2_0x5D [39% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 42% progress on ECUId:KAFAS2_0x5D [40% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 42% progress on ECUId:KAFAS2_0x5D [40% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 42% progress on ECUId:KAFAS2_0x5D [40% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 42% progress on ECUId:KAFAS2_0x5D [40% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 43% progress on ECUId:KAFAS2_0x5D [41% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 43% progress on ECUId:KAFAS2_0x5D [41% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 43% progress on ECUId:KAFAS2_0x5D [41% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 43% progress on ECUId:KAFAS2_0x5D [41% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 44% progress on ECUId:KAFAS2_0x5D [42% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 44% progress on ECUId:KAFAS2_0x5D [42% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 44% progress on ECUId:KAFAS2_0x5D [42% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 44% progress on ECUId:KAFAS2_0x5D [42% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 45% progress on ECUId:KAFAS2_0x5D [43% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 45% progress on ECUId:KAFAS2_0x5D [43% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 45% progress on ECUId:KAFAS2_0x5D [43% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 45% progress on ECUId:KAFAS2_0x5D [43% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 46% progress on ECUId:KAFAS2_0x5D [44% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 46% progress on ECUId:KAFAS2_0x5D [44% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 46% progress on ECUId:KAFAS2_0x5D [44% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 46% progress on ECUId:KAFAS2_0x5D [44% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 47% progress on ECUId:KAFAS2_0x5D [45% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 47% progress on ECUId:KAFAS2_0x5D [45% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 47% progress on ECUId:KAFAS2_0x5D [45% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 47% progress on ECUId:KAFAS2_0x5D [45% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 48% progress on ECUId:KAFAS2_0x5D [46% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 48% progress on ECUId:KAFAS2_0x5D [46% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 48% progress on ECUId:KAFAS2_0x5D [46% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 48% progress on ECUId:KAFAS2_0x5D [46% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 49% progress on ECUId:KAFAS2_0x5D [47% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 49% progress on ECUId:KAFAS2_0x5D [47% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 49% progress on ECUId:KAFAS2_0x5D [47% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 49% progress on ECUId:KAFAS2_0x5D [47% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 50% progress on ECUId:KAFAS2_0x5D [48% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 50% progress on ECUId:KAFAS2_0x5D [48% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 50% progress on ECUId:KAFAS2_0x5D [48% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 50% progress on ECUId:KAFAS2_0x5D [48% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 51% progress on ECUId:KAFAS2_0x5D [49% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 51% progress on ECUId:KAFAS2_0x5D [49% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 51% progress on ECUId:KAFAS2_0x5D [49% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 51% progress on ECUId:KAFAS2_0x5D [49% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 52% progress on ECUId:KAFAS2_0x5D [50% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 52% progress on ECUId:KAFAS2_0x5D [50% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 52% progress on ECUId:KAFAS2_0x5D [50% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 52% progress on ECUId:KAFAS2_0x5D [50% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 53% progress on ECUId:KAFAS2_0x5D [51% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 53% progress on ECUId:KAFAS2_0x5D [51% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 53% progress on ECUId:KAFAS2_0x5D [51% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 53% progress on ECUId:KAFAS2_0x5D [51% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 54% progress on ECUId:KAFAS2_0x5D [52% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 54% progress on ECUId:KAFAS2_0x5D [52% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 54% progress on ECUId:KAFAS2_0x5D [52% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 54% progress on ECUId:KAFAS2_0x5D [52% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 55% progress on ECUId:KAFAS2_0x5D [53% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 55% progress on ECUId:KAFAS2_0x5D [53% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 55% progress on ECUId:KAFAS2_0x5D [53% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 55% progress on ECUId:KAFAS2_0x5D [53% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 56% progress on ECUId:KAFAS2_0x5D [54% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 56% progress on ECUId:KAFAS2_0x5D [54% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 56% progress on ECUId:KAFAS2_0x5D [54% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 56% progress on ECUId:KAFAS2_0x5D [54% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 57% progress on ECUId:KAFAS2_0x5D [55% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 57% progress on ECUId:KAFAS2_0x5D [55% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 57% progress on ECUId:KAFAS2_0x5D [55% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 57% progress on ECUId:KAFAS2_0x5D [55% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 58% progress on ECUId:KAFAS2_0x5D [56% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 58% progress on ECUId:KAFAS2_0x5D [56% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 58% progress on ECUId:KAFAS2_0x5D [56% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 58% progress on ECUId:KAFAS2_0x5D [56% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 59% progress on ECUId:KAFAS2_0x5D [57% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 59% progress on ECUId:KAFAS2_0x5D [57% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 59% progress on ECUId:KAFAS2_0x5D [57% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 59% progress on ECUId:KAFAS2_0x5D [57% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 60% progress on ECUId:KAFAS2_0x5D [58% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 60% progress on ECUId:KAFAS2_0x5D [58% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 60% progress on ECUId:KAFAS2_0x5D [58% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 60% progress on ECUId:KAFAS2_0x5D [58% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 60% progress on ECUId:KAFAS2_0x5D [59% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 60% progress on ECUId:KAFAS2_0x5D [59% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 60% progress on ECUId:KAFAS2_0x5D [59% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 60% progress on ECUId:KAFAS2_0x5D [59% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 61% progress on ECUId:KAFAS2_0x5D [60% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 61% progress on ECUId:KAFAS2_0x5D [60% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 61% progress on ECUId:KAFAS2_0x5D [60% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 61% progress on ECUId:KAFAS2_0x5D [60% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 62% progress on ECUId:KAFAS2_0x5D [61% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 62% progress on ECUId:KAFAS2_0x5D [61% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 62% progress on ECUId:KAFAS2_0x5D [61% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 62% progress on ECUId:KAFAS2_0x5D [61% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 63% progress on ECUId:KAFAS2_0x5D [62% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 63% progress on ECUId:KAFAS2_0x5D [62% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 63% progress on ECUId:KAFAS2_0x5D [62% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 63% progress on ECUId:KAFAS2_0x5D [62% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 64% progress on ECUId:KAFAS2_0x5D [63% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 64% progress on ECUId:KAFAS2_0x5D [63% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 64% progress on ECUId:KAFAS2_0x5D [63% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 64% progress on ECUId:KAFAS2_0x5D [63% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 65% progress on ECUId:KAFAS2_0x5D [64% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 65% progress on ECUId:KAFAS2_0x5D [64% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 65% progress on ECUId:KAFAS2_0x5D [64% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 65% progress on ECUId:KAFAS2_0x5D [64% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 66% progress on ECUId:KAFAS2_0x5D [65% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 66% progress on ECUId:KAFAS2_0x5D [65% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 66% progress on ECUId:KAFAS2_0x5D [65% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 66% progress on ECUId:KAFAS2_0x5D [65% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 67% progress on ECUId:KAFAS2_0x5D [66% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 67% progress on ECUId:KAFAS2_0x5D [66% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 67% progress on ECUId:KAFAS2_0x5D [66% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 67% progress on ECUId:KAFAS2_0x5D [66% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 68% progress on ECUId:KAFAS2_0x5D [67% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 68% progress on ECUId:KAFAS2_0x5D [67% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 68% progress on ECUId:KAFAS2_0x5D [67% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 68% progress on ECUId:KAFAS2_0x5D [67% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 69% progress on ECUId:KAFAS2_0x5D [68% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 69% progress on ECUId:KAFAS2_0x5D [68% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 69% progress on ECUId:KAFAS2_0x5D [68% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 69% progress on ECUId:KAFAS2_0x5D [68% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 70% progress on ECUId:KAFAS2_0x5D [69% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 70% progress on ECUId:KAFAS2_0x5D [69% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 70% progress on ECUId:KAFAS2_0x5D [69% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 70% progress on ECUId:KAFAS2_0x5D [69% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 71% progress on ECUId:KAFAS2_0x5D [70% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 71% progress on ECUId:KAFAS2_0x5D [70% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 71% progress on ECUId:KAFAS2_0x5D [70% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 72% progress on ECUId:KAFAS2_0x5D [71% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 72% progress on ECUId:KAFAS2_0x5D [71% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 72% progress on ECUId:KAFAS2_0x5D [71% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 72% progress on ECUId:KAFAS2_0x5D [71% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 73% progress on ECUId:KAFAS2_0x5D [72% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 73% progress on ECUId:KAFAS2_0x5D [72% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 73% progress on ECUId:KAFAS2_0x5D [72% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 73% progress on ECUId:KAFAS2_0x5D [72% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 74% progress on ECUId:KAFAS2_0x5D [73% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 74% progress on ECUId:KAFAS2_0x5D [73% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 74% progress on ECUId:KAFAS2_0x5D [73% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 74% progress on ECUId:KAFAS2_0x5D [73% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 75% progress on ECUId:KAFAS2_0x5D [74% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 75% progress on ECUId:KAFAS2_0x5D [74% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 75% progress on ECUId:KAFAS2_0x5D [74% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 75% progress on ECUId:KAFAS2_0x5D [74% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 76% progress on ECUId:KAFAS2_0x5D [75% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 76% progress on ECUId:KAFAS2_0x5D [75% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 76% progress on ECUId:KAFAS2_0x5D [75% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 76% progress on ECUId:KAFAS2_0x5D [75% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 77% progress on ECUId:KAFAS2_0x5D [76% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 77% progress on ECUId:KAFAS2_0x5D [76% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 77% progress on ECUId:KAFAS2_0x5D [76% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 77% progress on ECUId:KAFAS2_0x5D [76% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 78% progress on ECUId:KAFAS2_0x5D [77% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 78% progress on ECUId:KAFAS2_0x5D [77% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 78% progress on ECUId:KAFAS2_0x5D [77% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 78% progress on ECUId:KAFAS2_0x5D [77% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 79% progress on ECUId:KAFAS2_0x5D [78% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 79% progress on ECUId:KAFAS2_0x5D [78% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 79% progress on ECUId:KAFAS2_0x5D [78% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 79% progress on ECUId:KAFAS2_0x5D [78% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 80% progress on ECUId:KAFAS2_0x5D [79% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 80% progress on ECUId:KAFAS2_0x5D [79% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 80% progress on ECUId:KAFAS2_0x5D [79% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 80% progress on ECUId:KAFAS2_0x5D [79% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 80% progress on ECUId:KAFAS2_0x5D [80% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 80% progress on ECUId:KAFAS2_0x5D [80% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 80% progress on ECUId:KAFAS2_0x5D [80% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 80% progress on ECUId:KAFAS2_0x5D [80% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 81% progress on ECUId:KAFAS2_0x5D [81% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 81% progress on ECUId:KAFAS2_0x5D [81% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 81% progress on ECUId:KAFAS2_0x5D [81% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 81% progress on ECUId:KAFAS2_0x5D [81% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 82% progress on ECUId:KAFAS2_0x5D [82% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 82% progress on ECUId:KAFAS2_0x5D [82% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 82% progress on ECUId:KAFAS2_0x5D [82% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 82% progress on ECUId:KAFAS2_0x5D [82% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 83% progress on ECUId:KAFAS2_0x5D [83% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 83% progress on ECUId:KAFAS2_0x5D [83% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 83% progress on ECUId:KAFAS2_0x5D [83% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 83% progress on ECUId:KAFAS2_0x5D [83% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 84% progress on ECUId:KAFAS2_0x5D [84% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 84% progress on ECUId:KAFAS2_0x5D [84% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 84% progress on ECUId:KAFAS2_0x5D [84% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 84% progress on ECUId:KAFAS2_0x5D [84% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 85% progress on ECUId:KAFAS2_0x5D [85% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 85% progress on ECUId:KAFAS2_0x5D [85% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 85% progress on ECUId:KAFAS2_0x5D [85% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 85% progress on ECUId:KAFAS2_0x5D [85% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 86% progress on ECUId:KAFAS2_0x5D [86% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 86% progress on ECUId:KAFAS2_0x5D [86% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 86% progress on ECUId:KAFAS2_0x5D [86% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 86% progress on ECUId:KAFAS2_0x5D [86% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 87% progress on ECUId:KAFAS2_0x5D [87% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 87% progress on ECUId:KAFAS2_0x5D [87% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 87% progress on ECUId:KAFAS2_0x5D [87% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 87% progress on ECUId:KAFAS2_0x5D [87% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 88% progress on ECUId:KAFAS2_0x5D [88% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 88% progress on ECUId:KAFAS2_0x5D [88% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 88% progress on ECUId:KAFAS2_0x5D [88% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 88% progress on ECUId:KAFAS2_0x5D [88% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 89% progress on ECUId:KAFAS2_0x5D [89% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 89% progress on ECUId:KAFAS2_0x5D [89% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 89% progress on ECUId:KAFAS2_0x5D [89% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 89% progress on ECUId:KAFAS2_0x5D [89% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 90% progress on ECUId:KAFAS2_0x5D [90% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 90% progress on ECUId:KAFAS2_0x5D [90% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 90% progress on ECUId:KAFAS2_0x5D [90% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 90% progress on ECUId:KAFAS2_0x5D [90% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 91% progress on ECUId:KAFAS2_0x5D [91% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 91% progress on ECUId:KAFAS2_0x5D [91% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 91% progress on ECUId:KAFAS2_0x5D [91% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 91% progress on ECUId:KAFAS2_0x5D [91% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 92% progress on ECUId:KAFAS2_0x5D [92% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 92% progress on ECUId:KAFAS2_0x5D [92% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 92% progress on ECUId:KAFAS2_0x5D [92% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 92% progress on ECUId:KAFAS2_0x5D [92% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 93% progress on ECUId:KAFAS2_0x5D [93% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 93% progress on ECUId:KAFAS2_0x5D [93% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 93% progress on ECUId:KAFAS2_0x5D [93% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 93% progress on ECUId:KAFAS2_0x5D [93% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 94% progress on ECUId:KAFAS2_0x5D [94% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 94% progress on ECUId:KAFAS2_0x5D [94% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 94% progress on ECUId:KAFAS2_0x5D [94% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 94% progress on ECUId:KAFAS2_0x5D [94% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 95% progress on ECUId:KAFAS2_0x5D [95% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 95% progress on ECUId:KAFAS2_0x5D [95% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 95% progress on ECUId:KAFAS2_0x5D [95% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 95% progress on ECUId:KAFAS2_0x5D [95% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 96% progress on ECUId:KAFAS2_0x5D [96% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 96% progress on ECUId:KAFAS2_0x5D [96% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 96% progress on ECUId:KAFAS2_0x5D [96% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 96% progress on ECUId:KAFAS2_0x5D [96% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 97% progress on ECUId:KAFAS2_0x5D [97% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 97% progress on ECUId:KAFAS2_0x5D [97% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 97% progress on ECUId:KAFAS2_0x5D [97% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 97% progress on ECUId:KAFAS2_0x5D [97% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 98% progress on ECUId:KAFAS2_0x5D [98% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 98% progress on ECUId:KAFAS2_0x5D [98% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 98% progress on ECUId:KAFAS2_0x5D [98% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 98% progress on ECUId:KAFAS2_0x5D [98% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 99% progress on ECUId:KAFAS2_0x5D [99% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 99% progress on ECUId:KAFAS2_0x5D [99% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 99% progress on ECUId:KAFAS2_0x5D [99% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 99% progress on ECUId:KAFAS2_0x5D [99% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 100% progress on ECUId:KAFAS2_0x5D [100% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 100% progress on ECUId:KAFAS2_0x5D [100% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 100% progress on ECUId:KAFAS2_0x5D [100% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: 100% progress on ECUId:KAFAS2_0x5D [100% of swfl_00001423-000_029_001] [TRANSACTION] [KAFAS2 - 5D - swfl_00001423-000_029_001] Transaction type: swDeploy; Message: TA finished [TRANSACTION] [KAFAS2 - 5D] finalizeECUFlash started [PROGRESS] [KAFAS2 - 5D] finalizeECUFlash finished [PROGRESS] [] finalizeVehicleFlash started [PROGRESS] [] finalizeVehicleFlash finished [PROGRESS] [] prepareVehicleForCoding started [PROGRESS] [] prepareVehicleForCoding finished [PROGRESS] [KAFAS2 - 5D] prepareECUforCoding started [PROGRESS] [KAFAS2 - 5D] prepareECUforCoding finished [PROGRESS] [KAFAS2 - 5D] authenticateECUforCoding started [PROGRESS] [KAFAS2 - 5D] authenticateECUforCoding finished [PROGRESS] [KAFAS2 - 5D - cafd_00001148-000_033_001] Transaction type: cdDeploy; Message: TA started [TRANSACTION] [KAFAS2 - 5D - cafd_00001148-000_033_001] Transaction type: cdDeploy; Message: TA finished [TRANSACTION] [KAFAS2 - 5D] finalizeECUCoding started [PROGRESS] MCDDiagService<id=80649, job=com.bmw.psdz.jobs.uds.MCD3_FinalizeECUCoding, service=WDBI_CPS - WriteDataByIdentifier Codierpruefstempel, description=error: negative response : requestOutOfRange, link=KAFAS2_5D_ETHERNET> [DIAGSERVICE] [KAFAS2 - 5D] finalizeECUCoding error [PROGRESS] [] job failed with negative response error: code: service returned global negative response description: Service WDBI_CPS returned a negative response with response code requestOutOfRange; LinkName: KAFAS2_5D_ETHERNET severity: ERROR [THROWABLE] [KAFAS2 - 5D] There was an error during TAL execution, please check the log files. [WARN] [KAFAS2 - 5D] - [Exception - KAFAS2 - 5d] job failed with negative response error: code: service returned global negative response description: Service WDBI_CPS returned a negative response with response code requestOutOfRange; LinkName: KAFAS2_5D_ETHERNET severity: ERROR [] finalizeVehicleCoding started [PROGRESS] [] finalizeVehicleCoding finished [PROGRESS] [] finalizeTALExecution started [PROGRESS] [] finalizeTALExecution finished [PROGRESS] TAL execution finished [TAL_EXECUTION_FINISHED] TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "17min 28s". [C206] Read SVT after TAL execution started. Read SVT after TAL execution finished.
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
