OFHG Change / Coolant Hose / Paranoid about belt?
05-22-2020, 11:16 PM | #1 |
45
Rep 106
Hey!
I recently was doing some preventative maintenance and changed the oil filter housing gaskets. During this process, I broke and replaced the coolant hose. I wish I would have known about the aluminum coolant hose flange before, I would have gone that route instead of putting another plastic hose back in. Anyway... I did all of this because I was concerned about all the horror stories from oil dripping on the accessory belt. During the process of doing the gaskets, the oil lines did in fact dump a pretty fair amount of oil on the belt - is this something to be concerned about, or is the real harm a continuous leak and I am just being paranoid? /rant Thank you in advance to any info!
Kennethavery.com // Portland Real Estate
Wagner Evo 1 IC // Active Autowerke CP // JB4 + BEF // CAtuned Coilovers // AR Design D/P // Future Classic Spacers // E46 OE CSL Wheels // (PURE Stage 2 w/ wedge next!) |
05-22-2020, 11:29 PM | #2 |
480
Rep 1,600
Belt is cheap, just change it for your peace of mind. Most E series cars should be due for a new belt anyway, by now. EPDM rubber is what your coolant hoses and belts are made of. It is not tolerant of fuel or oil exposure. The belt should always be removed if the risk of oil or coolant contamination is possible, which in this case is inevitable.
I have done this repair before with the belt installed because someone before had stripped out the alloy T60 tensioner hole. I covered it with a large plastic trash bag and heaps of rags. The real risk is long term exposure to incompatible substances. A lot of oil filter housing gaskets don't get fixed until they leak onto the belt anyway. Which by then they sling all over the hoses too. The rubber degrades/melts and expands, which then shreds or slips and then ends up inside your timing case. |
05-22-2020, 11:46 PM | #3 | |
45
Rep 106
I appreciate the response!
05-23-2020, 05:00 AM | #4 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
If you're worried about belt ingestion, thought about fitting one of these?
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
05-23-2020, 09:26 AM | #5 | |
45
Rep 106
Edit: Some pretty mixed reviews on the seller and the part itself. Going to hold off on that item until another solution becomes available.
Wagner Evo 1 IC // Active Autowerke CP // JB4 + BEF // CAtuned Coilovers // AR Design D/P // Future Classic Spacers // E46 OE CSL Wheels // (PURE Stage 2 w/ wedge next!) Last edited by skaper; 05-24-2020 at 12:08 AM.. |
06-04-2020, 04:50 AM | #7 |
616
Rep 3,194
I doubt there is an 'official' mileage in these days of 'lifetime fill'. I change mine (including tensioner) every 50K...
06-04-2020, 09:27 AM | #8 |
494
Rep 1,416
Yeah every 50k miles. The belts are so easy to change.
06-12-2020, 07:38 AM | #10 |
Hoonigan
6849
Rep 3,000
Drives: '09 328i, '98 Wrangler
It's a good idea, but I haven't seen any of their products in stock since they started the website. Ridiculous. Why market a product if you can't even sell it? I've e-mailed them for when they have them in stock for an N52, but no response.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
Efthreeoh17315.00 |
06-12-2020, 09:46 AM | #11 |
616
Rep 3,194
Sorry Josh, hadn't realised that. Wouldn't have bothered mentioning it if I'd known...
06-14-2020, 09:42 AM | #12 |
Rep 47
I changed my ofhg, as soon as I took the housing out some coolant went all over my belt. I ended up needing a bolt that unfortunately broke off in the head.. so I ordered a bolt and ended up not changing the belt coolant looked like it had all dried, I've been driving around for 1000km and no slipping and no damage to belt. We changed the ofhg on my friends car same thing some coolant went on the belt.
Waited 2 days for parts, drove the car 200km belt ripped in half but luckily did not get sucked into the front main.. So honestly I would recommend changing the belt to be 100% sure. |
06-14-2020, 12:04 PM | #13 | |
General
17315
Rep 18,737
06-14-2020, 12:06 PM | #14 |
General
17315
Rep 18,737
Drain the coolant first...
