BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Code P0446 - EVAP VENT CONTROL CIRCUIT FAILURE
      05-20-2020, 10:11 PM   #1
exwon
14
Drives: 2017 BMW X1
I own a 2017 X1. Got this code a month or so before corona. COVID-19 is nasty but I don't think it caused this code. Any idea what did?
The vehicle ran normally before and after the code appeared, and continues to run normally. It seemed to show up around the time after my key fob required a batter change, but I really don't want to go down a rabbit hole thinking it has anything to do with that - unless it does for some crazy reason.
This was the only link I found related to the problem for BMW:
https://www.carobdcodes.com/bmw-p044...formance.shtml
My vehicle will not pass inspection until this code is resolved.
Thanks for any thoughts you might have!
      05-21-2020, 12:57 AM   #2
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Have you spoken to a dealer yet? It might be simple, it might not! A simple phone call may get the problem solved.
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      05-21-2020, 04:50 AM   #3
Beagler
75
Drives: Sept 2019 Facelift X1 MSPORT
https://www.obd-codes.com/p0466
Everthing goes to Entropy in this Age.
      05-21-2020, 03:14 PM   #4
exwon
14
Drives: 2017 BMW X1
Thanks for the replies!
The link is a good one.
And I did call BMW tech who said it is most likely the valve in a line coming out of the gas tank. But they'd have to diagnose to know for sure, i.e., supply power to the valve to see if it fails to open or not. That diagnosis alone is pushing $150. If the valve is faulting, replacing it with a new one is pushing another $400 to $500 (ballpark estimate).
It could also very well be electrical, which I would think could be much less $ to fix.
Anyway, they don't see this code often with the X1.
Beagler74.50
      05-23-2020, 06:23 AM   #5
rameer
Drives: 2016 BMW X1
I had a similar issue few months back and took it to the dealership and they estimated for close 1000. So got it fixed outside and paid close to 300 I believe. It ended up being a vent value which apparently is a common problem in the model.
Dealership is wanted to replace intake muffler at the same time for some reason and I had no reason why.
      05-25-2020, 10:06 PM   #6
exwon
14
Drives: 2017 BMW X1
Thanks for the post. Dealerships, gosh... They'd probably want to first remove my tint citing difficulty seeing the issue.
It just happened that today, on my way back from home improvement store, I noticed the engine light was OFF! Maybe a fluke. I'll check it tomorrow. Been driving my other car past several days now that it's nice out. No idea if the X1 just sitting there cleared something but I was cautiously optimistic.
I had looked into a shop next to my normal one that works on European cars and has a "smoke gun" tool to see if the valve opens properly... But maybe I'll just try to get it inspected next month, if the engine light continues to stay off by then! Cuz driving the car seems to have zero effect from the code...
      06-03-2020, 11:58 AM   #7
exwon
14
Drives: 2017 BMW X1
well, code came back the next day. i'll address it the next time i can get a ride to my car shop. i'll try to remember to post the results for the forum.
      06-05-2020, 05:53 AM   #8
rameer
Drives: 2016 BMW X1
Happened to me as well. It came and then gone and then came and the. Pretty much stayed. I tried to reset it with OBD diagnostics app but it would come back again.
      06-12-2020, 04:00 PM   #9
Ridin'Dirty
Ridin'Dirty's Avatar
60
Drives: '93 'Beemer' R100r, '17 X1(S)
Have a look at this TIS article for associated componets description:
https://www.newtis.info/tisv2/a/en/f...ank/1VnYQzvMlL
      06-24-2020, 07:23 PM   #10
stephanmcoffey
Drives: bmw x1 20i (2018)
I recently installed a dash cam hardwired into my 2018 x1 in the 104 fuse location, and since then whenever i go to fuel up the pump keeps clicking off on me which leads me to think it is something to do with my vent valve. any ideas on what could help determine the fuse which is conected to the vent valve to try replace it and see if this fixes the issue before i try uninstalling my dashcam before finally going to a dealership
      04-06-2021, 07:34 AM   #11
Tusflyer
Drives: BMW F48 X1
Just had this issue occur on my 2016 F48, it’s only the P0446 that presents.. I tried a new gas cap and that wasn’t it.. chased down an electrical issue as my obd tool kept telling me that my battery had low voltage, replaced the battery and no change BUT when I was working under the hood I got some really strong fuel vapors. I looked up fuel TSB’s for the MY in the US and BINGO! TSB B010419 covers the issue and BMW even extended the warranty to 10 years/120k miles (This only covers 2016 and very early build 2017 models however). I took it to the dealer where they had quoted me several hundred dollars in goose chase diagnostics and they were quite surprised that I had found the TSB and warranty, I told them to only look into the fuel valve and guess what? That was the issue.. saved myself a boatload!
Try this first if you only have the P0446 code! Good luck!
Appreciate 2
CliveL163.00
      04-10-2021, 11:29 PM   #12
acouch12
Drives: BMW X1
Hello,
I'm having the same issue as the original poster. I'm trying to do the replacement myself but cannot locate the fuel tank vent on my 2016. I can't find any videos or walkthroughs for a newer X1. Any help would be appreciated. I was going to take it to the dealership with that TSB but apparently it will not apply in AZ.
      04-21-2022, 09:33 AM   #13
bwtech
Drives: BMW X1
If I'm getting P0446 with a P0440, would it still be the same issue? I am doing some googling and if there are both, It might be the valve itself I need to replace. Thanks!
      04-21-2022, 11:17 AM   #14
jrveron
jrveron's Avatar
Argentina
266
Drives: 2023 X3 m40i
Originally Posted by acouch12 View Post
Hello,
I think you're talking about this: https://www.realoem.com/bmw/enUS/sho...diagId=13_1620
I changed it a couple of days ago. It's super easy (see attached), and the sensor costs ~$90.
File Type: pdf 13 90 500 Replacing tank vent valve (B32, B38, B42, B46, B48).pdf (267.5 KB, 422 views)
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD
      04-22-2022, 07:41 PM   #15
rice_rocket88
No_Country
298
Drives: E60 F48 F39
Aww nuts, so my wife just told me and I pulled the same code. The only thing is that the part does not match yours: ours has a dual hose valve, not a single one. I verified the different part numbers and both are compatible, but definitely not the same!
13907614013
Any good way to actually troubleshoot the valve? Do you hear it click on and off? The genuine ones seems out of stock, I'm not sure if I dare use a no name part. I'll call up my dealer tomorrow and see if they have one in stock.
      04-23-2022, 10:41 AM   #16
jrveron
jrveron's Avatar
Argentina
266
13907614013
Hi rice_rocket88! I believe the difference is that I have the EU model, while you have the US model.
To be honest, I didn't get a code. I'm troubleshooting an idle problem. The revs vary while starting the engine and don't keep at a certain level like it is supposed to. First, they go a little down to 600 RPMs (makes you believe the engine will stop) and then immediately go up higher to 1700 RPMs or so. Other than that, the car drives great.
Not even the BMW service guys could diagnose my problem, so I'm changing what I read here and there that could be its root: MAF sensor, throttle body, fuel vent sensor, etc. But no luck so far .
      04-23-2022, 10:58 AM   #17
rice_rocket88
No_Country
298
Drives: E60 F48 F39
Oof that's a real bummer.. I called my local bmw and the valve is in stock so I'm just going out the door to get it.. see if it'll make the evaporate code go away before I take the car to an expert for diagnosis.
      04-23-2022, 05:16 PM   #18
jrveron
jrveron's Avatar
Argentina
266
Good luck, bud! After installing the new sensor, you know, you should probably reset the error memory using BimmerLink, BimmerCode, ISTA, etc.
      04-23-2022, 05:47 PM   #19
rice_rocket88
No_Country
298
Drives: E60 F48 F39
Yes for sure..I reset it once and it came back right away, so hoping this is simple and easy.
      04-28-2022, 03:33 PM   #20
rice_rocket88
No_Country
298
Drives: E60 F48 F39
4 days later and it's still clear.. I do believe that was the bum part!
      04-28-2022, 03:51 PM   #21
Skyline2.0
137
Drives: 2018 BMW X1 xDrive
A bit late to the party, but I'm attaching a helpful BMW service bulletin that I found awhile ago when I got a check engine light (I believe error code 191C02) that was pointing to a faulty tank vent valve (B46 engine).
My valve didn't have the visual defect noted in the attached document. But, the dealer did replace the vent valve under warranty as it was loose/defective. I was also able to fix a loose connector issue because I knew what it should've looked like from my own disassembly experience.
Hope the attachment helps future members.
      04-28-2022, 08:41 PM   #22
46-90-48
46-90-48's Avatar
Drives: X1
Hello,
any luck with this issue/code? Has the same code and, so far, same results on 2016 F48.
I tried aftermarket valve, but nothing changed, waiting for Saturday to inspect bottom of the car and look at canister connectors.
