Transfer Case Fluid Change!
05-13-2020, 07:28 AM | #1 |
F86, G05, E91
455
Rep 778
Decided to change fluid while doing the oil filter housing, belt and tensioner and other maintenance. Glad it did...
Only 5 oz of fluid came out of case!! Car didn't have any CELs or codes, and seemed to drive fine except for slight shudder under load. I think that might have been the xfer case complaining but will find out when back together. There was quite a bit of fluid debris on carrier and in are, so there is definitely a slow leak. Car hasn't had fluid replaced in the past so not bad for 150k. I'm not going to worry about that. Will check bolts for tightness and get back together. |
05-13-2020, 09:44 AM | #2 |
eBay Special
3091
Rep 3,034
Drives: E90 330xi
Let us know how it drives afterwards. Im at 142k and I just got an oil wear code for it
Common sense is a flower that does not bloom in everyone's garden
05-14-2020, 08:41 PM | #3 | |
F86, G05, E91
455
Rep 778
Yellow triangle with an arrow 4x4 CEL Brake Limp home mode Ran a scan with Foxwell. Exhaust cam position sensor. VTC worn fluid Limp mode enabled Misfire cylinder 1 Jeez. Brutal start. Decided to take it for a spin around block. That cleared the driveline lights! Sweet. I think xfer case adapting to actually having fluid! As far as the cam sensors, I think when I hit the cam sensors with degreaser to clean front of engine from leaking oil housing I damaged them. Whoops. I thought I could get away with that. 2 new ones and two coil packs on way (1 for cylinder 1, and a spare). Not sure why coil suddenly died. Ran cylinder deactivation test from Foxwell and only cylinder 1 issue. Hopefully smooth sailing after this. Will report back on the xfer case performance after running smooth. |
05-14-2020, 09:54 PM | #4 | ||
eBay Special
3091
Rep 3,034
Drives: E90 330xi
DgjoX6M2016455.00 |
05-15-2020, 05:28 PM | #5 | |||
F86, G05, E91
455
Rep 778
colorado.e9x3091.00 jame92r10.50 |
