F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 Headlights replaced after crash Coding
Studio RSR
      05-08-2020, 04:52 PM   #1
BeMyWheels
Drives: F22
Smile F30 Headlights replaced after crash Coding
Hi guys, first can I say this forum is amazing!
I have got E-SYS, updated PSDZDATA file (lite), and currently trying to get ISTA -D
The car is a facelift M-Sport, with Full LED headlights, and I am replacing with Full LED shadow edition headlights
The new lights are completely dead, from what I can read on the forums, they need reprogramming, (throwing lots of errors too).
The forums I can find now, all have dead URL links, any help guys?
I have used ESys cheat sheets to code with, and need to also learn how the cheat codes work included with the launcher
Thought would be cool to have a post without any links to download software just tutorials?
Did take pictures of light modules if that helps?
Much appreciated
      05-11-2020, 05:05 AM   #2
BeMyWheels
Drives: F22
Hi guys
I have now gone into Ista
Re learned height sensor
Re learned indicators
Code FEM - from the test plan
And in e-sys just clicked code on the FEM module
The car no longer shows all errors it just says headlight range control
Neither light is working
I got pictures and videos coming
      05-11-2020, 05:28 AM   #3
BeMyWheels
Drives: F22
Errors before clear
Pictures of my errors before i cleared anything
      05-11-2020, 05:35 AM   #4
BeMyWheels
Drives: F22
Exclamation Errors after clear
following the clear, i did a ride height calibration under body, and then code new indicators, then followed this test plan
youtube video of me going through the steps
Car shows headlight vertical control after
I CAN GIVE TOKENS PLEASE PM/DM
      05-11-2020, 05:36 AM   #5
atzebmw
Germany
588
Drives: Tesla Model 3
Mark the fle module in the SVT table, assign a CAFD and code it.
Do the same for the second fle module.
Poochie9104.50
      05-11-2020, 06:38 AM   #6
BeMyWheels
Drives: F22
Thanks for Reply! no CAFD
Hi thanks for the reply, I just went to check and i can not see CAFD in either of those modules image attatched
      05-11-2020, 06:48 AM   #7
atzebmw
Germany
588
Yes, because the modules are "new" for your car and you have to assign the CAFD first.
So mark the FLE, then on the right side "detect caf for swe" and a window opens. Choose the bottom CAFD or the CAFD with the highest numbers and hit OK.
Then hit the button "Code".
Do the same for the second FLE.
      05-11-2020, 07:29 AM   #8
BeMyWheels
Drives: F22
they WORK
OH MY GOD,
This has just made my day
Thank you for giving some time to help a complete stranger
Did exactly as you showed and selected the last CAFD option?
And no errors and lights work properly
Think I may need to align them but looks good!
Thanks again!
(I CAN GIVE TOKEN PM ME)
      05-12-2020, 04:07 AM   #9
MasterShaw
Drives: BMW F34
atzebmw You are a legend I couldn’t get my LED headlights coded in and this is what I was missing.
Thanks man ��
      05-12-2020, 05:06 AM   #10
atzebmw
Germany
588
Thanks man ��
Glad I could help
      06-09-2020, 03:29 AM   #11
fabianx
Drives: BMW 3 GT F34 318d
Glad I could help
Hi,
i want to make a retofit on my car 3 GT F34 12/2013, from halogen to led headlights (not adaptive), and i don't want to install the level sensors.
regarding the coding of led headlight (not adaptive):
1. after i will assign with esys the CAFD will be need other codings?
2. i don't want to install the level sensors, so i could get some errors, and i read that will be necessary to add an option (i think is 5A2 led headlights, not adaptive).
3. how to add option 5A2 in FEM and REM.
4. My car is made in 12/2013, the i-drive software will need update?
thank you
thank you in advance.
      02-25-2023, 08:08 PM   #12
AMcKinney94
Drives: 2017 330i xDrive
Can anyone please send me a link to download Ista so I can program my new LED headlight on my f30. I can’t find a legit download anywhere.
      02-25-2023, 11:25 PM   #13
TheNine90
578
Drives: bmw
Its better to use esys to program it. PM me i can send you a copy of esys
      04-22-2023, 03:43 PM   #14
dwightklewis
Drives: BMW F31 335d
atzebmw i have just followed your instructions and happy to inform that it worked a treat for one side. The only issue i have is that i am missing FLE 44. Any ideas on this? can i copy FLE 43 and rename to 44?
      04-27-2023, 05:32 AM   #15
TheNine90
578
Drives: bmw
Check connector. It usually loose connection of the module isn't responding. You can swap the module and check if the module is the issue or the connection
      09-15-2023, 01:09 PM   #16
PedroRios
Drives: Bmw 320i f30
Does anyone know how to disable the angel eyes completely? Even when you have a position light or headlight on? Via bimmercood
      09-15-2023, 01:13 PM   #17
PedroRios
How to remove the light error of the angel eyes burned from the panel? I removed the lights and would like to stay without them and without the error in the panel, via bimmercode...
Tags
coding, encode, esys, f30, headlight, ista, led, programming, reprogram, token
f30post
