05-08-2020, 10:01 AM | #1 |
No 55mph
1622
Rep 8,477
*SOLD* GFB DV+ Diverter Valve for N55
I Have FS: SOLD
(1) NEW/UNUSED GFB DV+ Diverter Valve for N55 #T9356 (Not compatible with the M2) I Purchased this New for my 435 N55 from Mike @ XPH, so it is Guaranteed Genuine, Decide To Go Another Direction with My Build... By retaining the factory ECU control and recirculating the vented air, the DV+ is a purely performance-oriented product that offers the following benefits:
> Retains the factory solenoid coil for seamless integration > Replaces plastic valve parts with metal for reliability and strength on chipped engines > Direct-fit replacement with GFB’s TMS benefits > Exclusive “pilot-actuated” valve mechanism for rapid response at high boost This currently goes for $135 from XPH... SOLD! to ghatiey1990 - Thanx! No Worries Dealing with Me - Check My iTrader/Long Time Forum Member Includes All That Came Originally https://gfb.com.au/products/blow-off...abarth-detail/ From the Mfg: GFB expands the DV+ range with a direct-fit solution for the weak factory diverter valve used on many European vehicles. The solenoid coil itself from the factory-fitted valve is great (the ECU opens it faster than any pneumatic valve so why replace it?), but the weak point however is the valve mechanism itself. So GFB’s DV+ solves this problem by replacing just the valve parts with an anodised billet aluminium housing fitted with a brass piston machined to exacting tolerances. The end result is sharper throttle response, lightning-fast valve actuation, and it will hold as much boost as you can throw at it. On with the Pics:
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
05-09-2020, 03:12 PM | #3 |
No 55mph
1622
Rep 8,477
Replied
05-09-2020, 05:07 PM | #4 |
No 55mph
1622
Rep 8,477
