Burning rubber smell and white smoke after changing plugs and ignition coils
05-07-2020, 08:21 PM | #1 |
Rep 12
Title says it pretty well. I switched the plugs and coils. It fired up, sounds great, and runs perfect. I got down the road and smelled burning rubber. Popped the hood and there's a small amount of white smoke coming from middle to rear ignition coil area. I drove straight home, popped the hood, and there was still smoke; although the smell wasn't as strong.
I used Bosch ignition coils and plugs. My car is a 2011 335i with an n55. Thank you for any help! |
05-08-2020, 09:15 AM | #2 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Something dropped on the exhaust while you were working? Plug not torqued down properly? Wiring trapped against something hot?
I'd take the cover off and have a long hard look at everything you touched...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
