05-07-2020, 12:50 PM | #1 |
56
Rep 96
Seized M performance brakes?
I recently had a company that paints calipers, cars etc paint my yellow m performance brake kit a red color to match my new 3 series. When I received them the first time, this guy really was dumb enough to paint over my brake pads & also didn't let my paint heal. So I took them back for him to repair it and instead of replacing my pads he sands them down! Not only that but he painted over my pistons. At this point I'm furious and I asked him to replace my whole brake kit and he's refusing saying his job was only to paint. I'm going to do a small claims report on him but I want to know if my calipers are seized from these pictures alone? Is this repairable? Just need a second opinion. Company IG : @mgscarcustoms
2022 M3 COMPETITION SKYSCRAPER GREY
05-07-2020, 12:56 PM | #2 |
1996
Rep 2,499
Wow, tell us where you got that done so we can avoid it. Must be a fly by night shop. I can't believe they went through the trouble of removing the calipers but didn't spend 5 minutes taping off the pistons and removing the pads.
Either way, they probably work OK for now. There doesn't seem to be enough paint on the pistons to seize them. |
05-07-2020, 01:01 PM | #3 | |
56
Rep 96
The company instagram is @mgscarcustoms located in Los Angeles.
05-07-2020, 01:06 PM | #4 |
480
Rep 681
Not entirely surprised they didn't bother to tape off the pistons when one of the first things I see on their insta is a set of wheels with tires taped off being painted rather than being dismounted and properly sprayed.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
iScramble76.00 |
05-07-2020, 01:08 PM | #5 |
56
Rep 96
One of the reasons why I thought it would be a whole lot easier dropping off my calipers instead of having them on my car, but I should of took that as a red flag on my end.
05-07-2020, 01:11 PM | #6 |
480
Rep 681
I would look into rebuilding the calipers you had painted now. You'll probably need to pull the pistons out to clean and redo the orings after. You can DIY them (brembo should have steps somewhere) or take them to a shop.
2006 997.1 C4S |
05-07-2020, 01:13 PM | #7 | |
56
Rep 96
05-07-2020, 01:15 PM | #8 |
1996
Rep 2,499
I think it's somewhat common though lazy to have a bit of paint on the pistons. I doubt it would cause any issues. At the very least though, they should get you a new set of pads. Even if sanding works, it looks stupid to have those painted as well.
05-07-2020, 01:27 PM | #9 |
56
Rep 96
Yeah man he refused that as well. Saying that "my mechanic says nothing is wrong. He works on Ferrari's, bmws etc. and says the pads are fine that they just need to be sanded down" lol he said I was exaggerating. Dudes out of his mind and refused to buy me new ones.
05-07-2020, 01:36 PM | #10 |
219
Rep 209
I would question proper function of the pistons/seals. Also their longevity, as paint might dry/lead to cracking of rubber its sprayed on. Paint on hot brake pads doesn't sound like a good idea either. Maybe the red they sprayed on is high temp but still, not stoked about painted pads.
The shop need to fix their mistake no matter what. Small claims court might be a good way of convincing them to learn how to paint in the future. I have done my fair share of stupid things in my life too but the person who painted the calipers might be favored for this year's Darwin award |
EddieF3056.00 |
05-07-2020, 02:07 PM | #11 | |
56
Rep 96
But yeah small claims is the move at the moment if he doesn't pay up! Has to learn the hard way.
05-07-2020, 03:09 PM | #12 | |
No 55mph
1622
Rep 8,476
Me thinks you would have done a better job yourself by painting with G2 Caliper Paint & a brush
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
05-07-2020, 08:10 PM | #13 | |
poopycat
266
Rep 791
This 100%. If paint got in the caliper piston, it's done. Not a hard job to r&r, but pistons and seals might cost a lot. I'd be after that and labor estimates. Best of luck OP! |
05-09-2020, 07:46 AM | #14 |
BMW CCA 69606
86
Rep 227
Sloppy work, no doubt........by all parties. Who decided not to remove the pads?
Rebuilding caliper is not needed. There is zero chance paint got to the caliper piston and seal.....the dust boot prevent this. Install and post pics. |
05-09-2020, 08:01 AM | #15 |
poopycat
266
Rep 791
Except you will need to pull the caliper, pull the piston, and replace it. Reread it "if paint got in it", you can't deny that work. A dust boot is for dust, wow amazing reading.
05-09-2020, 10:56 AM | #16 |
5886
Rep 10,256
EddieF30, thanks for sharing what is a cautionary tale of fundamental absence of professionalism. Painting calipers is one of the easiest jobs - as long as an experienced technician was assigned to the task. Did business owner provide an opportunity to speak with the technician? I suspect the technician never painted calipers before.
EddieF3056.00 |
05-09-2020, 12:48 PM | #18 | |
BMW CCA 69606
86
Rep 227
You absolutely do not need to disassemble the caliper. Paint "didn't get into it" because of the dust boot. The paint on the end of the piston that contacts the pad, does not affect the ability of the caliper to hold brake fluid. |
05-09-2020, 02:08 PM | #19 | |
127
Rep 283
A shoddy job which is a shame. |
05-09-2020, 08:07 PM | #20 | ||
56
Rep 96
05-09-2020, 08:08 PM | #21 | |
56
Rep 96
05-09-2020, 08:55 PM | #22 | |
219
Rep 209
To me, it comes down to how determined you are to teach them a lesson. If it is worth it to you, small claims is a nice way to deal with it. If you want to cut your losses you can just drop the case and hope that karma will come back to them Regarding you refurbishing the calipers I would do a complete rebuild and new paint. Maybe their current state does not affect function (if dust covers were meant to be painted over they would have been from the factory) but, it will bug me that they are not done right. In any case, I am very sorry for your experience. Obviously a "business" that does not deserve to have customers. Last edited by Palantir; 05-09-2020 at 09:05 PM.. Reason: Added info |
