Parasitic draw - Battery Dead
05-06-2020, 07:11 PM | #1 |
Rep 31
I recently started getting a warning that there was an increase in battery discharge when I start my car. Went to start my car the other day and the battery was dead enough that it wouldn't even crank. Battery is fairly new so I suspect something other than the battery itself.
Put the car into sleep mode and measured for a draw on all of the fuses. Only one fuse gave me a reading (0.9 on a 5 amp fuse). Fuse was number 74 which is assigned to the instrument cluster. Has anyone see anything like this before? Any suggestions on things to try? I hate to think of the process of pulling out my instrument cluster. And even if I did that, I'm not even sure what I would be looking for. I'm hoping for some input so I don't do something stupid. Thanks.
2009 335xi Le Mans Blue; JB4 - Map 5; flashed, VSRF DPs, VSRF Intercooler, transmission flash, VSRF chargepipe, LED interior, Angel Eyes, Glossy Black Grill, spolier, Rear Fog Light Mod, backup camera mod, 2020 Nav. Maps;
05-09-2020, 12:17 PM | #2 |
Rep 31
Update: Removed my instrument cluster and took it apart. Couldn't see any obvious defects on the circuit board. I removed the step motors that drive the 4 gauges, and plugged it back in. That eliminated the parasitic draw.
Through a process of elimination I narrowed down the parasitic draw to a single faulty step motor and have one on order. I'm hopeful that once I replace the motor and put everything back together, it will be good as new!
05-09-2020, 07:03 PM | #3 | |
648
Rep 2,013
335i e92 TPC 19Ts
