05-02-2020, 06:46 AM | #1 |
158
Rep 295
Spoiler install: best tape position?
I have seen a number of install videos and posts. But does anyone have any pics to use as a guide on where the best place is to install the tape on the spoiler is? Ideally for an F33.
A couple of close ups of where OEM or other high-quality 3rd party spoiler manufacturers have positioned the tape would be helpful. Thanks!
Shawzy44
2023 BMW X3 M40i 2019 BMW X5 40iX 2019 BMW 440iX M Performance Cabriolet |
05-02-2020, 10:28 PM | #2 | |
1599
Rep 3,748
05-03-2020, 08:29 AM | #3 |
2466
Rep 5,457
Drives: F30
While we are in on the topic....
Does anyone know the proper thickness of tape that should be used? Im installing an F80 spoiler soon and was wondering what mm thickness the factory would have used to originally apply it. |
05-03-2020, 09:46 AM | #4 | |
1599
Rep 3,748
We will see soon enough...in just clean an OEM F36 spoiler. It does have a lip on it where the tape is... I'm also worried, but the tape that was there originally is not thick either. I don't see any other tape thicker than 45 mil. Maybe non 3m tape.... but I have a few disappointment using those. Last edited by Gen13 F36; 05-03-2020 at 10:19 AM.. |
sspade2466.00 |
05-03-2020, 11:17 AM | #5 | |
poopycat
266
Rep 791
PREP WORK IS EVERYTHING Clean everything with alcohol, do not assume surfaces are clean out of the box. I've seen shit explode on itself because people just "stuck it on". |
05-03-2020, 11:56 AM | #6 |
Monobloc
332
Rep 447
Drives: '02 M Coupe - '19 F31 330ix
Like the homies said, "it's all in the prep."
I highly recommend purchasing 3M adhesion promotor specifically meant for their acrylic foam tapes. Don't use the clear VHB tape. You want the gray acrylic foam tape as these are incredibly strong once stuck down in place. Definitely figure out what correct mil (thickness) you need for attaching your spoiler. One last tip, once you have the 3M tape affixed to the spoiler undo about an inch or so of the liner from the ends, just enough for you to pull away. The purpose of this is to give one the ability to 'dry' mount for a precise fit with the tape in place. Once you are happy with the location, hold the spoiler in place and pull away the double-sided tape liner for a perfect fit. You basically have one shot to get it right so this would prevent any curse words or objects from flying. I learned this pro-tip from the official BMW mudflap install instructions.
-2023 Honda Odyssey Elite - Sonic Gray Pearl / Black
-2019 F31 330ix Individual - Champagne Quartz / Coral Red (M-sport, Exec, Premium, Track) -2004 Honda CRV AWD - Silver / Black -2002 S54 M Coupé - Steel Gray / Dark Gray/Black Last edited by Moupe; 05-03-2020 at 12:09 PM.. |
sspade2466.00 |
05-03-2020, 12:02 PM | #7 | |
1599
Rep 3,748
Of course good prep is needed Last edited by Gen13 F36; 05-03-2020 at 12:11 PM.. |
05-03-2020, 12:23 PM | #8 |
Respect My Authoritah
368
Rep 873
There are a few 62mil thicknesses available and lots of automotive specific products for badge application. 3M 5962 would be a good option if you ever plan to remove it and keep the lip intact. 3M CV62F is a commercial vehicle tape that would be more permanent.
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
sspade2466.00 |
05-03-2020, 12:50 PM | #9 | |
1599
Rep 3,748
I already bought the vhb 5952... I'll find out soon enough. There is also this 3m RP62... its 62mil. I don't know the difference but it is acrylic foam too |
05-03-2020, 12:56 PM | #10 | ||
368
Rep 873
05-03-2020, 12:57 PM | #11 |
16
Rep 63
Be sure you get the original 3m double-sided tape in the original 3m package since the imitation tape does not last and falls apart in the heat.
This is the original 3m tape I got for my spoiler and other trims. This bonds really well and have had no issues. https://amzn.to/2SLn2Nt Last edited by jcortez75; 05-08-2020 at 09:04 AM.. |
05-03-2020, 01:31 PM | #12 | |
poopycat
266
Rep 791
PREP WORK Yay |
05-03-2020, 01:34 PM | #13 | |
poopycat
266
Rep 791
05-04-2020, 12:26 PM | #14 |
1310
Rep 883
Per the OPs question - heres some pics of the M Performance front splitter for the 4-series M Sport as it ships. It’s an amazing piece — the finish, weight and fab precision are aerospace quality.
Each side of the splitter only has 4 pre-installed automotive tapes - with the very useful ‘flag ends’ on each one to facilitate easy removal of the tape backing once the splitter is located in place during installation. It’s unmarked tape (no 3M branding) and it’s actually thinner than the standard 3M foam tape. (BMW can likely go thinner due to above mentioned fab precision as everything is exact dimensionally and surface-wise.) As you can see, BMW has the tapes installed just in critical additional spots, complementary to the splitter’s built-in structural mechanical fastening locations which match up to the cars bumper/underbody points. They apply the tape approx. 3/8” to 1/2“ from the part edges. Hope this is useful! .
05-04-2020, 12:41 PM | #15 | |
1599
Rep 3,748
I guess for some reason alot of people call the front lip as a spoiler. Front lip aka splitter... aka spoiler... aka air dam.. so much damn names. So not to confuse .m.i said trunk spoiler |
05-04-2020, 01:36 PM | #16 |
1310
Rep 883
Since the OP said he had an F33 vert I assumed he meant front vs rear ‘spoiler’. I didn’t think there was an OEM F33 rear ‘spoiler’. ??
I don’t disagree that you’d want tape near the edges on a rear ‘spoiler’ that’s hanging off your rear deck having no mechanical attachment.
05-04-2020, 05:31 PM | #17 | |
873
Rep 1,079
Now I recently bought Betalink to do the job permanently and not waste another 2-3 hours removing and clearing the spoiler in case the edges don't stick perfectly. Then I started reading some threads mentioning Betalink a nightmare to work with so I don't know what to do. If anyone wants OEM CF M Perf spoiler and Betalink let me know Or maybe I'll just do it |
05-04-2020, 05:45 PM | #18 | |
448
Rep 909
05-04-2020, 05:47 PM | #19 |
873
Rep 1,079
Betalink is supposed to be permanent, he shouldn't have removed it. Is it OEM M Perf CF Spoiler? It's a bit tricky on the edges.
05-04-2020, 05:48 PM | #20 |
448
Rep 909
It was the OEM M Perf spoiler. If you betalink, i'd expect to be happy with how you place it and never expect that shit to ever come off. Strong stuff.
05-04-2020, 06:15 PM | #21 | |
1599
Rep 3,748
JUST an F36....extra door, slower than you
AWE Quad Exhaust, Bootmod3 VMR v804 GM 19" Staggered |
05-04-2020, 07:40 PM | #22 | |
873
Rep 1,079
