F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > 437M wheels on xdrive f30
GetBMWParts
      04-30-2020, 12:36 AM   #1
cactusjack350
cactusjack350's Avatar
Drives: BMW 335xi F30
I am in the market for some 437M wheels and I am curious if the 9 inch wide wheels with 255/35/19 tires will fit in the front of my xdrive 335i? And also do the 10 inch wide wheels with 275/35/19 tires fit in the rear?
Jack Thomas
      04-30-2020, 07:32 AM   #2
HarryTee
HarryTee's Avatar
214
Drives: 2020 M4CP & 2017 440i GC
Are they the 19 inch?
If 19, they should fit but if you're extra-cautious then use 245/35/19 (front) and 265/35/19 (rear) tyres. These are the tyres on my wheel set of the exact same specification with the 437M, and they fit without the slightest problem.
      04-30-2020, 09:21 AM   #3
weehe126
1161
Drives: 2017 340i
Yes they should fit, but you need to match tire sizes so the diameters are the same front and back.
      04-30-2020, 02:45 PM   #4
kpgray
GasCompressor
kpgray's Avatar
333
Drives: 2022 Porsche 911 Cabriolet
The xDrive requires the tires are within 1% of diameter to prevent any issues. The standard 19" staggered set up has a wheel height of 26", 1% is 0.26".
The following Standard Staggered tires are 0.1" or less that 0.5%, this is OK:
  • Front: 8.0" Rim: 225/40ZR19 = 26.1"
  • Rear: 8.5" Rim: 255/35ZR19 = 26.0"
The following tires are 0.5" or 2%, this is double recommendation and may be a problem:
  • Front: 245/35/19 = 25.8"
  • Rear: 265/35/19 = 26.3"
The following tires are 0.6" or greater than 2%, this will be a problem:
  • Front: 255/35/19 = 26"
  • Rear: 275/35/19 = 26.6"
2022 Porsche 911 Cabriolet Agate Grey/Black PDK
2019 440i M-Sport Smoke Topaz Metallic/Opel (Sold)
2014 335i M-Sport Black/Beige MPPK/MPE (Totaled)
2013 328i Sport xDrive Imperial Blue/Grey (Sold)
      04-30-2020, 02:48 PM   #5
cactusjack350
okay thanks i'll make sure
Jack Thomas
      05-01-2020, 04:22 PM   #6
mcintoshf30
184
Drives: 2014 F30 335xi
I've been running 255/35/19 & 275/35/19 on my 335 xDrive without any issues, I am running xDelete now though so there isn't concern about rolling diameter differences. It does rub sometimes when full lock but that's about it.
      05-01-2020, 04:46 PM   #7
HarryTee
HarryTee's Avatar
214
Originally Posted by mcintoshf30 View Post
I've been running 255/35/19 & 275/35/19... It does rub sometimes when full lock but that's about it.
Just a slight reduction on the width as I did: 245/35/19 & 265/35/19
Then it's perfect. No rubbing at all.
      06-24-2022, 05:41 PM   #8
TheUnicorn340
TheUnicorn340's Avatar
Drives: 2017 6mt 340i X-Drive
Would this also apply to b58 xdrive models?
      06-25-2022, 12:31 AM   #9
ewizzle
ewizzle's Avatar
35
Drives: '22 X5 45e & '22 JLU 4xe
Engine size/type has nothing to do with tire rotation. xDrive is xDrive. Same rules will apply.
f30post
