04-27-2020, 03:58 AM | #1 |
59
Rep 129
b48/ b58 emerging issues
Knowing the nightmare that emerges with the N20, what is the thinking and what are the possible issues seen on the B48 that people have found.
I am only 9K miles and one year, into ownership of a four year lease car that I really plan to buy out but only if it is a better bet than the ill-fated N20 cars. So tell me the worst
(OO-(lllll)(lllll)-OO)
04-27-2020, 04:31 AM | #3 | |
59
Rep 129
If you don't know just say. My car has been garaged since March 23rd 2020, but, in the rest of the world the engines have been in circulation since 2016
NBMW3017.00 |
04-27-2020, 06:06 AM | #5 |
68
Rep 117
Last winter I got "drivetrain malfunction" error at cold starts, the mileage was approximately 50k km. If the engine was turned off and started again, the error always went away. Drove to an indy shop for diagnostics, the error was caused by wastegate valve that was not properly opening while the engine was starting, thus ECU was shutting down the turbo. Mechanic manually flipped the wastegate fully open for several times, and the error have not appeared ever since. I guess some dirt made a way to the rod that operates the wastegate, and it was jamming a little and required some extra effort to open.
This March, at the mileage of 75k km, I replaced the radiator that started to rot, but the roads here are extremely salty and dirty during winter, so that should not be an issue in milder climate. Other than that, the vehicle was flawless in terms of engine and transmission. |
04-28-2020, 11:43 AM | #6 | |
339
Rep 660
Drives: 2014-320Xi / 2017-330Xi
So yor F30 is what 6 years max and the radiator corroded? |
04-28-2020, 12:51 PM | #7 | |
68
Rep 117
It's not that it was visibly corroded or lost some of its cooling efficiency. But I usually wash the radiators once in 2 years, and this time the guys at the shop warned me that the radiator core seems already weak enough and will probably break and crumble while being pressure washed. So I decided to put a new radiator in advance. There are some factors that could facilitate and possibly explain a faster corrosion: I don't exaggerate saying that roads are extremely muddy and salty here It can take a half-hour drive in winter to change car's appearence from completety clean to totally greyish-dirty. Thus I never wash my car from November to April, so all the shit that went on radiator stays there for several months, stimulating the corrosive processes. Finally, a fair share of my mileage consists of highways and B-roads, so there were a lot of stone hits (some were severe enough to even break the plastic grille in front of radiators), and they could probably add some damage to radiator core. That said, I have never read anything about premature radiator corrosion on f30s on our local forums. The second car in our family, 2007 volvo s60, is still driving in same conditions with its original radiator (despite its age it has a mileage comparable to my f30, though). So I suppose that it's possible that the unit on my car was just faulty in terms of corrosion protection. |
Pauloxxi339.00 |
04-28-2020, 06:03 PM | #8 | |
1646
Rep 4,877
If you're looking for skewed confirmation bias that the product you purchased may have issues, then bravo, you have 100% succeeded. You could also . There are so many ridiculous threads about "tell me your problems". I'm going to flip it the other way: If you are asking this question, then you bought the wrong car, period. EVERY brand has problems. |
les anderson145.50 fnholland0.00 |
04-29-2020, 04:02 AM | #9 | |
59
Rep 129
I asked for the very specific reason as all the blurb on here relates to N20, and so far,,,, so far!! very little said about the B48. The brilliant thing about these forums is that it is a very efficient way to cut through the bullshit of "my car's wonderful it can do 0-60 in a second and a half,,,,, and get to the hard nuts. I plan to lay out my hard earned, to buy the car out it's lease in just under three years however, if it emerges that it has underlying issues the way the N20 had, I will let it go and move along to a G10 or G20 (as no way will I buy a Beaver face 4 series,,,) My apologies that my question offends but as a hobby restorer and mechanic, I am specifically seeking the doom & gloom here, with very good reasons.
04-29-2020, 08:28 AM | #10 |
214
Rep 496
"My apologies that my question offends"
It doesn't offend but is rather silly with "emerging issues" and "nightmare" upfront. That was the reason for my early reply, but my sarcasm was obviously not obvious enough |
04-29-2020, 12:23 PM | #12 | |
59
Rep 129
But I'll be sure to never ask a question about a BMW on a BMW board ever again
04-29-2020, 12:29 PM | #13 | |
59
Rep 129
Given that weekly on this very board, owners report catastrophic failures on N20's many of whom,never previously appreciating the potential of the timing chain issue, I thought my question fair and reasonable. I think owners who sadly have an engine let go might use much stronger language than "nightmare" so your right on that score So where else apart from a BMW model specific board, do you suggest someone seek this information from care to suggest a source?
04-29-2020, 03:53 PM | #14 |
1646
Rep 4,877
If you're looking for reliability, find a source that reports reliability on cars. Asking for the 10 people with bad experiences out of 10 million that have had stellar experiences gains you nothing.
If you have seen all these catastrophic failure posts weekly on this forum, then I suppose you just answered your question (if a skewed sample set is what you need). |
04-29-2020, 04:33 PM | #15 |
5886
Rep 10,256
B48 is a 4 cylinder engine based on modular design. B58 is essentially B48 with 2 extra cylinders. BMW made a lot of improvements in B48 engine. Worth searching for N20 vs B48.
04-29-2020, 10:20 PM | #16 |
109
Rep 295
Drives: 2016 340i X Drive
2016 B58 with almost 50k miles. Other than “slow down, slow down, you’re taking the turn too fast” complaints from the passenger seat area, no engine issues.
04-30-2020, 06:56 AM | #17 | |
59
Rep 129
Ha ha ha yip brother,,, that's 100% the kind of problem I want to hear about
04-30-2020, 07:09 AM | #18 | |
59
Rep 129
My 420i is no longer running at 184Hp /290Nm as an example, and knowing how reliable it is guides my thinking on leaving it making 250Hp / 374Nm or toning it down to maybe 220Hp /340Nm, due to a weakness in some component part or other. I reckon I am in this car for a rather long time as I plan to make it my weekend hobby car once the lease ends.
04-30-2020, 11:24 AM | #19 |
1646
Rep 4,877
I think you're missing the point. You are only going to hear from the handful that have issues and not the bazillion that do not. NOBODY posts saying things are "doing fine". There are only rant posts about how the car died and left them stranded.
04-30-2020, 01:45 PM | #20 |
24
Rep 36
I'm pretty new to BMW and did a fair bit of reading before buying a used 2017 340xi. I didn't find anything that stands out as a 'problem'. I've read about oil consumption, but I haven't had that. I'm ready for my second oil change. Bought with 43k in Jan and close to 60k now.
05-01-2020, 02:59 AM | #22 | |
59
Rep 129
Right at the start of the Nikasil issue, people thought it was just a misfire, then they thought it was head gasket failure only when we all started to come together did we find the pattern of short journey cars that didn't get heated properly, petrol washing the oil off the bores, and BINGO! but had we not analysed it, it would have been so very costly, and the introduction of Alusil taken far longer,,,
