04-25-2020, 01:41 PM | #2 | |
417
Rep 919
Otherwise, I'm going to suggest $400 is a lot to replace a fuse. (The diagram is hiding in one of your fuse boxes--good luck figuring out the fuse from the diagram, but maybe you'll find it. Second guess was some recent work and the connectors came off but didn't go back on...or a wire was damaged. All guesses, OP...I doubt both horns themselves, failed. Maybe the steering wheel mechanism itself (not sure where the switch is or how hard it is to get to)...but your car is new, so that's doubtful. Go to the TIS and see what they say about the procedure...if you did actually need new horns...I'd doubt they're that hard to do even if diying. realoem.com for your part number needs. newtis.info for the bmw tis
04-25-2020, 01:45 PM | #3 | |
Rep 31
I noticed it a few months ago, sometimes my horns would work, other times it was a high pitched one. |
04-25-2020, 01:47 PM | #4 |
417
Rep 919
I'd guess something central then...the switch (in steering wheel) or the fuse.
Of course, I've been wrong, but the odds of the horns themselves failing together seems really slim. Have you checked the horn fuse?
04-25-2020, 01:49 PM | #5 | |
Rep 31
My question is that a fair normal price? |
04-25-2020, 04:05 PM | #6 | ||
4488
Rep 10,473
upsidedownfunnel1996.00 |
04-25-2020, 04:19 PM | #7 |
8243
Rep 16,083
A word to the wise, ask before you take it in to the shop for anything. Or google the problem yourself. In this case this is only one of many options you'd have found:
04-25-2020, 06:51 PM | #8 |
Rep 31
Yeah, I'm not going to take off a wheel, etc to do that. I don't even have the tools to do that, let alone patience
04-25-2020, 07:11 PM | #10 |
1599
Rep 3,748
04-25-2020, 07:34 PM | #11 | |
4488
Rep 10,473
Well within reason for a Dealership repair. You might have saved a little less than $100 if you purchased horns online and taken to independent. However, after seeing some crappy front bumper alignments after they have been off, I'd certainly feel safer at Dealer unless I knew the Indy's work well. |
04-25-2020, 07:50 PM | #12 |
417
Rep 919
Sorry, OP, I didn't know the answer to your question but was otherwise trying to be helpful.
04-25-2020, 09:14 PM | #13 | |
8243
Rep 16,083
See video above.
Fliplegend1471.00 |
04-25-2020, 10:06 PM | #14 |
1599
Rep 3,748
Saw that video long time ago... I know you don't need to remove the bumper big BUT here.... the dealer will do that is why they charge crazy money. It sucks to know how dealer do it. That's why research is the key to most easy DIY
04-25-2020, 11:19 PM | #15 | |
¯\_(ツ)_/¯
537
Rep 1,000
04-26-2020, 02:43 AM | #17 |
2JZ-GTE
3042
Rep 3,996
Sorry for your loss.
Dead horns. A new low. |
04-26-2020, 06:57 AM | #18 |
417
Rep 919
...and a new high.
Not very long-lived horns. smh
04-26-2020, 08:08 AM | #19 |
8243
Rep 16,083
Spend five minutes in New York City and you'll wish there was no such thing as horns. Idiot after idiot leaning on their horns when there's no where to go anyway.
04-26-2020, 01:54 PM | #20 |
2595
Rep 3,030
Just an insight - this is a common issue with F30. Both mine failed at about 65k.
BMW covered parts and labor under warranty.
2016 BMW F80 ZCP
Instagram : 7IM3LESS https://instagram.com/7im3less?igshid=YmMyMTA2M2Y= |
04-26-2020, 01:56 PM | #21 |
1996
Rep 2,499
Like IK6SPEED said this is fair for a dealership repair. They're definitely not ripping you off for what they're doing.
But I personally don't think it makes much sense to take an out of warranty car to the dealership to repair something as trivial as horns. Not unless it's some special car that you want to keep forever. An indy shop could use a quality 3rd party part (Hella) for a fraction of the cost and they would charge $100 labor. They are accessible without removing the front bumper so I wouldn't worry about alignment or extra labor costs. This type of work is also the type of work you could attempt on your own without worrying about messing anything up too badly. |
04-26-2020, 02:30 PM | #22 |
1599
Rep 3,748
Horns can fail as early as 15k miles... mine did and covered under warranty...since then I've been research how to replace them... just in case they broke after the warranty is over.
